does anybody know a good program that allows split screening
Avisynth can do this very easily. http://www.avisynth.org/Stack
There's the syntax. Then you can just frameserve to your encoder or editing software.
If you want something with more of a graphical interphase, Adobe After Effects does this very well. Simply drag and drop as many stills or videos onto the screen as you want, and work with them in layers.
Best program to split .ts audio from video?
By R55B in forum EditingReplies: 1Last Post: 30th Oct 2010, 08:09 -
What is my screening format?
By perik in forum Newbie / General discussionsReplies: 5Last Post: 16th Jun 2010, 21:51 -
Is there such a program which can split up this 1 .mp3 into single songs
By natty in forum Newbie / General discussionsReplies: 6Last Post: 8th Apr 2009, 21:35 -
Split .tp files, which program?
By Strawjellybelly in forum EditingReplies: 2Last Post: 29th Jan 2009, 11:04 -
What is the best program to split/cut/edit HD videos ??
By ZaYoOoD in forum EditingReplies: 7Last Post: 7th Jun 2008, 15:55
