I've captured some video from my Sony Handycam into Premiere Pro (version 7). The video clip is widescreen, just over 6 minutes and is 1.30 gig in size.
I want to export it into a quicktime file, to place on the internet. But everytime I use Premieres export feature either the video will come out in full screen, pixilated and still 1.30gig or it will come out as a file which is 5 or 6k in size and will not open. I am only using the preset options in Premiere.
Any ideas where I'm going wrong
Sytem Specs
OS Windows XP Home
P4 2.6 Gig
256 MB Ram
120 Gig Maxtor Harddrive
You're WAY below the recommended 1GB of ram to run PPro. So that might be the source of the failed 5k encodes.
I don't know about the wide to full screen issue, a good place to ask about that is
http://www.creativecow.net/forum/view_posts.php?forumid=3
As for ideal good PPro QT export settings for the web, people suggested the following on another web site.
"Export out of quicktime to a quicktime movie.
Video:
Choose the mpeg4 codec,
set it to 62 quality, and
set key frame distance to 75
Frame rate 15
Use Qualcomm or QDesign for audio depending on if it's voice or music, note one of these these have options in PPro that include optimizing for streaming.
Adobe Premiere export same as original file?
By kray in forum Newbie / General discussionsReplies: 13Last Post: 9th Sep 2012, 01:05 -
Export Problems (Premiere Pro CS4)
By BoLane in forum EditingReplies: 0Last Post: 11th Oct 2011, 11:55 -
Problems Capturing/Importing Video into Adobe Premiere Pro
By Texas in forum EditingReplies: 3Last Post: 15th Apr 2010, 02:56 -
Best export settings in Adobe Premiere CS4
By Polesch in forum Newbie / General discussionsReplies: 5Last Post: 5th Apr 2010, 18:45 -
Adobe Premiere Pro: I used DV footage and Photoshop stills - how to export?
By neckneck in forum EditingReplies: 12Last Post: 20th Dec 2009, 16:29
