Which one is the best firewire card under $100. Thanks for help.
Maybe someone else knows more about this than me, but aren't all IEEE 1394 PCI cards basically the same?
A $20 card should work as well as a $100 card. -
I don't know. I think I read somewhere that some particular chipset based cards are better than other. I am trying to avoid that confusion. Thanks
Well, the Texas Instruments chipset is the one that I've seen recommended in the past. Just about any firewire card that you find will be a Texas Instruments chipset, though, so that shouldn't be a big concern.
I bought a very cheap ($20) or so OEM PCI card and have never had a problem capturing from my DV camcorder. As long as my hard drive has space and is defragmented, I capture without dropping any frames.
What do you used for a PCI xpress firewire card?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 5th Sep 2011, 21:45 -
URGENT! Firewire card for computer
By dakota413 in forum Capturing and VCRReplies: 9Last Post: 10th Aug 2011, 18:22 -
does capture of firewire use the sound card?
By Cazz in forum Capturing and VCRReplies: 4Last Post: 24th Jan 2010, 17:45 -
Motherboard Firewire versus Add-in Card Firewire
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2008, 12:19 -
What Firewire Card for a Camcorder?
By rakun in forum ComputerReplies: 5Last Post: 12th May 2007, 10:20
