Thanks Baldrick, I think now I got the right forum for my question, right! How can I fix up the problem about tinted small squares full of the screen around 3 to 5 seconds while playback my movie. I was try to fix it up by VirtualDub 1.5.10, but the results is:
1.) a popup warning come up to tell me about the movie have an improper VBR audio encoding, but actually the movie had been found the audio sync with video.
2.) a popup warning desn't come up, that's mean the movie contain proper VBR audio encoding, but actually the movie had been found audio lose sync with video.
So how can i fix it up? I want to make it in good audio sync with video & don't want to see that popup warning. Thanks!
Closed Thread
one topic is enough.
https://www.videohelp.com/forum/viewtopic.php?t=231395&highlight=
we will move it if you post in wrong forum.
Remove green/purple "bloom" from video
By mikeveli20 in forum RestorationReplies: 4Last Post: 3rd Oct 2011, 15:08 -
3D Left+Right files to Anaglyph Red/Cyan or Green/Magenta
By eummagic in forum Newbie / General discussionsReplies: 10Last Post: 2nd Jan 2011, 20:24 -
I need a genuis!!! Heavily red tinted or red hue.
By mikekrauser in forum Authoring (DVD)Replies: 4Last Post: 16th Aug 2009, 19:51 -
Any Simple Fix for Fraps or Xfire codec videos showing up green in avidemux
By ZZen in forum EditingReplies: 2Last Post: 6th Jun 2009, 13:51 -
green vertical bar on left, purple verticle bar on right, source B&W VH
By lipwak in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th Jul 2008, 21:29
