I just got TMPGEnc Plus, and whenever I encode it does this whole step where it analyzes the video first, and then creates the file. It takes twice as long as with the free TMPGEnc. How do I skip the analyzing stage?
I also have another question about encoding to DVD from XVID. It seems that when I choose the NTSC format the audio and video are way out of sync, as the video goes by way too fast. However, when I choose NTSC (Low Resolution) it works fine. How do I fix it so that I can use regular NTSC encoding on XVID files?
Thats because you have asked it to do a 2-pass VBR encode. For single pass you need to use CQ mode or CBR (constant bitrate)Originally Posted by justified
Open the XVID in gspot or virtualdubmod. The audio is probably a VBR MP3. Tmpgenc hates those most of the time. You shoould extract the audio, save it as a CBR 48 Khz WAV file, then use that to encode to DVD.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik
Looking for tools/suggestions for analyzing CCTV security video
By JLittle2 in forum Newbie / General discussionsReplies: 0Last Post: 12th Jun 2010, 13:58 -
Would like help analyzing video conversion problems.
By Back2Future in forum Newbie / General discussionsReplies: 2Last Post: 5th Jan 2009, 14:51 -
auto gk takes too long analyzing source
By miguel22 in forum SubtitleReplies: 0Last Post: 18th Nov 2008, 14:01 -
Video analyzing software
By Xavier in forum Newbie / General discussionsReplies: 6Last Post: 17th Apr 2008, 10:01 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
