Help I have been converting files from XviD to DVD using Paddy's method (see http://www.paddysworld.co.uk/DVDConversionGuide.htm)
I have recently done one & the sound is so low when played back that the TV as to be turned right up to be able to hear it. What has gone wrong with this conversion can anybody help please.
TIA
Hello,
Check out virtualdub. I believe you can boost the audio with this. If not you could strip out the audio as a wav. Then use a wav editor to boost the audio. Next use the new audio and the old video for your conversion.
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Need suggestions from pros on how to process low-level audio
By Asterra in forum AudioReplies: 2Last Post: 1st Jul 2011, 20:57 -
FFDshow audio decoder level is way too low...
By MidnightMike in forum AudioReplies: 2Last Post: 4th Dec 2010, 01:34 -
Need help with low level hum (audio attached)
By sdsumike619 in forum AudioReplies: 10Last Post: 22nd Aug 2010, 03:34 -
MP3 track - low voice level
By Digiface in forum AudioReplies: 5Last Post: 30th Jul 2007, 18:05 -
LOAD CLICK AND LOW SOUND at join of 2 avi xvid ac3 using vitualdub
By hawklight in forum EditingReplies: 0Last Post: 15th Jul 2007, 09:44
