Ok, this is driving me crazy now, making a DVD is like rocket science!
I have some MPEG1 files taken from a Digital Camera (Photograpy), and I need to make a DVD with them..
Problems I have.
A. They are the wrong aspect ratio. 640 x 480. They are also FPS 25 and Aspect 1:1 (Details taken from DVD-Lab.)
B. The audio is 32khz, and has to be 48khz. (Dvd-lab can fix this, but because of problem A. all I am left with is sound to play with)
C. I think I need MPEG2 to make a DVD video. But am I wrong?
This is really driving me nuts now, I have downloaded Nero Vision Express, but I only got the SE version, which doesn't do feck all for me apart from VCD. If I get the correct (full) version, will it solve my problems and let me import these files I have?
If not, what do I need to do, I could download a million programs and spend a thousand pounds and still not have a working DVD. I'm at a lose end now.
Please help me. Sob.
Hello,
I believe tmpgenc can resize the video for you. You need 720x480 {mpeg2-ntsc} or half d1 (352x480-ntsc) for dvd compliant video. Then you can load the new video into dvdlab and have it mix the new video and convert the audio (to 48hz). Then it should be ready for authoring. Just a warning, you may run into sycnh issues, if so there are plenty of guides on this site for that problem.
For tmpgenc go into project wizard, load video, choose dvd settings, load correct resolution, process.
One other possibility: many DVD players can play MPEG files on ISO data disks. If you can live with that you may not need to do any conversion. Of course you won't have fancy menus, chapter stops, etc.
Originally Posted by junkmalle
Originally Posted by bugster
Many. -
Bugster, Sorry! I edited the "most" part out right after I posted. You managed to capture the original message.
The list shows 71 percent of 547 players tested support MPEGISO. That is what I based my "most" on. But since another 3615 players weren't tested I decided to retract the statement.
VCD/Mpeg1 to DVD/Mpeg2 - tools?
By shira in forum Video ConversionReplies: 5Last Post: 5th Jan 2011, 20:49 -
Avi to (MPEG1, MPEG2 PS)
By kilee in forum ffmpegX general discussionReplies: 7Last Post: 27th Dec 2010, 18:39 -
remuxing mpeg1 audio to mpeg2
By ChaosOrb in forum Newbie / General discussionsReplies: 3Last Post: 9th Sep 2009, 14:25 -
Question about which is more clear, mpeg1 or mpeg2?
By jimdagys in forum Newbie / General discussionsReplies: 12Last Post: 25th Sep 2008, 01:08 -
Mpeg Streamclip_DVD to Mpeg1 or Mpeg2
By edit204 in forum Newbie / General discussionsReplies: 1Last Post: 9th Nov 2007, 10:58
