Hi guys basically what i want to do is demux ac3 (from avi) then change to 2-channel stereo so i can load into tmpgenc (along with the video) and convert to dvd compliant mpeg 2 . After i demux (the ac3) from avi how do i change ac3 to some 2 chan stereo format so i can load into tmpgenc, and convert to compliant pcm?
You are in breach of the forum rules and are being issued with a formal warning. One topic is enough.
/ Moderator Baldrick
Closed Thread
if you are gonna make dvd you can leave it as ac3 and just convert the video to mpeg2 dvd. read this guide
https://www.videohelp.com/guides.php?guideid=447&howtoselect=4;10#447
if you anyway want to convert to pcm you can use ac3 acm decompressor and virtualdub
www.videohelp.com/virtualdubaudio
replace ac3 2ch with ac3 5.1 ch in mkv (and sync)
By umbbra in forum AudioReplies: 1Last Post: 12th Jun 2010, 05:18 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 12:23 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 20:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 11:24 -
H264 + AC3 + AC3 --> VOB - What is wrong with my command line?
By olik in forum ffmpegX general discussionReplies: 5Last Post: 3rd Feb 2008, 08:06
