Hi,
I have a VCD film which I have tried to transfer to Video tape and all I get is a B+W picture, but with good sound.
The video is connected via scart to my Philips DVD player.
Is this something to do with NTSC/PAL?
I am new to this and hope there is a simple solution for getting this transfered.
Many thanks
Strongbow
On 2001-11-18 09:23:51, Strongbow wrote:
Hi,
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Well, there are many options for this:
- Maybe your DVD-Player is set to YC (S-VHS) - Output? then all you get is the Luminance-Signal without any color.
- could be a problem with NTSC/PAL, but I doubt it. If your recorder is recording, then it should be ok.
- Do you get a color-picture when you set your vcr video-input to the dvd and look at the tv-screen (on the vcr-input)?
VCR/VHS playback - lines on picture...vcr alignment problem or no?
By daysaf00 in forum Capturing and VCRReplies: 1Last Post: 23rd Jan 2012, 01:54 -
It's not easy being 'green'.Looking to transfer VHS via VCR to computer
By Iceman107 in forum Newbie / General discussionsReplies: 7Last Post: 11th Feb 2010, 17:31 -
which is prefered jvc vcr for transfer?
By greenbag in forum RestorationReplies: 19Last Post: 27th Dec 2008, 21:08 -
Capture clueless, VCR transfer to computer ?
By mcicki in forum Capturing and VCRReplies: 1Last Post: 19th Feb 2008, 21:24 -
Best VCR OR VCR/DVD COMBO for restoration
By demonwarrior in forum Newbie / General discussionsReplies: 7Last Post: 24th Aug 2007, 03:02
