I have a motherboard with dual DDR capabilities (4 slots). I am currently using 1x512mb @ 333mhz.
I have a faulty 512mb 400mhz memory chip that I will be sending back as soon as I have some info on this subject.
Should I get another 512mb @ 333mhz and utilize the dual-ddr capabilities of my motherboard or should I just use 1x512mb @ 400mhz ?
Is dual (2x512mb @ 333mhz) faster perfomance than single at a higher bus speed? (1x512mb @ 400mhz)?
(I am looking for speed right now, not future expansion)
much talk make wise men think
try this link see if it helps
https://www.videohelp.com/forum/viewtopic.php?t=228379&highlight= -
Single 400MHz RAM. More bandwidth. I have dual-channel RAM in my machine and it doesn't make too much difference compared to a higher bus speed.
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 04:16 -
Dual Input display in a single monitor
By torrentkid in forum DVB / IPTVReplies: 1Last Post: 26th Jul 2010, 06:43 -
Dual Core or single does it really matter for captures. Which mainboard?
By gll99 in forum ComputerReplies: 114Last Post: 16th Aug 2008, 18:16 -
AMD 4200+ Single Core to Dual-Core Upgrade Issue...
By Bodyslide in forum ComputerReplies: 7Last Post: 30th Nov 2007, 16:45 -
How do I seperate 2 discs froma single dual layer 8 gig VTS files
By xkeots in forum MacReplies: 3Last Post: 11th Nov 2007, 11:48
