  1. i bought a new LG DK8621N dvd player. i copied the original disc of lord of the rings using intervideo dvdcopy2 with dvd idle running in the background. my question is why is it that the copy from the original cant be played in my new LG dvd player while my samsung dvd player can? btw, both dvd players has the capabilty to play DVD+/- R/RW discs. both are multi region. the LG support team said it must be in the burn speed used during burning. help. tnx!
    Feb 2004
    WI.
    Are you able to play other movies you've backed up in that player? Have you tried other media? I don't think you are giving enough information for anyone to really help you.
  3. yes all other back ups i made are able to play on my samsung dvd player and other players of my friends. i only have a problem with dvd-r's but not with dvd-rw's which can be played on both of my players. tnx for the reply. appreciate it.
  4. What exactly does the LG player do when you load the disc?
