Hello, im getting like 7seconds between each video tracks.
How can i fix that.
7 seconds between tracks of what? is it a dvd? (s)vcd? avi on a standalone player? avi's on your computer?
Im making a dvd with some old music videos,
the quality is really good, but i have a big gap
between each track. -
If you want an easy way of dvd authoring use tmpgenc dvd author,it will let you trim the unwanted footage from each track.
thats the program im using for it.
The problem is that once each music video(track) is over
it takes longer than the usual to go to the next one. -
What you can do is put all the clips in the same track and then set each chapter point at the beginning of each clip.
need to equalize volume of a single track made by appending 3 track
By perfection in forum AudioReplies: 2Last Post: 23rd May 2011, 02:57 -
Get audio track from DVD Extra instead of film sound track in VIDEO TS
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 12:25 -
How to select audio track opening multi-track container in avisynth?
By lovyagin in forum Video ConversionReplies: 7Last Post: 23rd Sep 2009, 12:16 -
2 audio different language track playing in the same time...
By AkaTaKlysm in forum Newbie / General discussionsReplies: 2Last Post: 5th Feb 2008, 18:06 -
re-encode only video track of Quicktimes but keep audio track untouched
By brennbaer in forum Newbie / General discussionsReplies: 6Last Post: 29th Jul 2007, 08:25
