hello,
Im using Tmpgenc, and Dvd Author, they work great.
Now im making a music dvd with some old rock videos,
picture is great and all, but theres a gap of like almost 7seconds
between the videos. How can i fix that.
Thanks.
I am assuming this gap is between clips on the disk after you have burned it. The only way to get rid of this gap for certain is to take it out before you author the DVD. This would mean getting the original clips, going into an editor, joining them all together, then re-encoding and reauthoring the disk with chapter stops for each clip.
Otherwise, it is dependent on how quickly your player can move across the disk and seek the next clip. Even if you have all the clips one after the other, there is a certain time overhead involved for the player to determine what the next title is, locate it, load it and begin playing. Some players will do this faster than others. If you have them all in a single title, you don't have this problem. -
Hello,
Have you tried placing the chapter points closer to the start of each video in Tmpgenc Dvd Author?? You can manually place the chapter start for each clip. It won't shave the time off but you could easily use the chapter skip button to shave 4-5 seconds off (manually of course). Just a suggestion.
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Video about Time Capsules
By kandalf in forum Newbie / General discussionsReplies: 0Last Post: 20th Dec 2010, 11:21 -
Video crashes all the time
By manicradio in forum Software PlayingReplies: 4Last Post: 9th Oct 2010, 22:38 -
reduced video time
By avextraxjp in forum Newbie / General discussionsReplies: 1Last Post: 22nd Feb 2009, 16:23 -
Need a video card that will run s-video and vga at the same time
By fordguy in forum ComputerReplies: 4Last Post: 22nd Mar 2008, 10:42 -
By fordguy in forum ComputerReplies: 1Last Post: 20th Mar 2008, 13:57
