Can anyone help? I used DVD Decrypter to rip the VOB files but when I used DVD2AVI I got the .d2v file but no audio file. Does anyone know? I was ripping Remember the Titans, does the THX sound have something to do with it? This is the first time I have encountered this, usually I get a .d2v file and an ac audio file but not on this movie. Any suggestions.
I think it is about DTS which cannot rip with dvd2avi. Look for DD 5.1 instead.
In DVD2AVI if you press F5 it will preview the movie, under audio it will tell you the format. Keep going thru the tracks till you get one that it can understand (like DD). Short note: the DD 2_0's are usually commentaries. Also if you select Demux All Tracks you will under DD and MPEG Audio it will extract all the audio streams, these can be converted with azid.
Correct AR(aspect ratio) on dvd2avi conversion (16:9 vs 1.85:1)
By Visual-Artist27 in forum DVD RippingReplies: 10Last Post: 19th Aug 2010, 23:11 -
DVD2AVI/DGIndex Aspect Ratio Problem (Long/Stretched Faces, etc)
By munkeyman in forum DVD RippingReplies: 7Last Post: 19th Feb 2010, 09:47 -
ASF2VC1 & transcode the audio WMA to AC3, then mux video VC-1 and audio
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 08:02 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 04:12 -
How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 08:38
