  1. Member tatester's Avatar
    Jul 2004
    Hi there,
    I've been using tmpgenc version 2.5 to enocde (S)VCDs and I haven't had a problem ever. Now when I've been trying to encode avi to dvd format I keep getting an error message stating "error writing stream" and always in the last 20 or so minutes of the encoding which VBR 2 pass.
    I've had this with 2 different avi files and when I've checked them in virtualdub and there hasn't been a problem. I know I have enough disk space but this error seems to have come from out of the blue. I use the dvd templates in tmpgenc and unlock them to set the bit rate of the audio/video.
    Is it me or the software?
    Any help will be greatly appreciated
    Thanks in advance
    fat32 partition? and the mpeg file is just under 4GB?
  3. Member tatester's Avatar
    Jul 2004
    yeah my drive is fat32 and the file that is output size of the mpeg2 that I do get when the error occurs is 3.99GB. I'm also using Windows 98SE. Hope this helps.
    the fat32 file limit is 4 gb. you could lower the video bitrate in tmpgenc and make a smaller file or convert to two video files.
    or upgrade to win2k/xp/linux and use ntfs/linuxjhadkh partitions.
  5. Member tatester's Avatar
    Jul 2004
    Thanks a lot for that, it's certainly taken away the frustration factor now that I know what the problem is.
    Cheers
