  1. Hello.To You All
    Sorry for my english its verry bat but i try it
    I have are problem to play this Enemy At The Gates movie and avi exstension it whil not play in Windowsmediaplayer 7 and i have install the right codecs,when i try to play it ther is no sound only when I play it in The Playa it good quality but olso no sound
    640 x 272, 24 bits, 81745 frames, 23,976 frames/sec, 191 kB/sec, DIVXMPG4 V3
    Nandub v1.0rc2
    What wrong.
    Please Help me.
    Mail me at hansgrietje2001@yahoo.de.
    Thanks.
    Greatings from FTPduren.
    FTPduren
  2. Hello.
    I have are problem to play this Enemy At The Gates movie and avi exstension it whil not play in Windowsmediaplayer 7 and 6,and i have install the right codecs,(Nimo4331,Nimo433,DivX411Bundle,DivX411Code c)
    But when i try to play it ther is no sound only when I play it in The Playa it good quality but olso no sound
    What's wrong.
    Please Help me.
    Thanks.
    Hans Duren.
    FTPduren
  3. Hello.
    I cant fix the movie whit sound i have try many thing but notting is working.
    Help me out plaese.
    Enemy At The Gates:Software Nandub v1.0rc2
    #include <stdio.h>
    #include <stdlib.h>
    #include <windows.h>
    #include <vfw.h>
    #include "AudioSourceAC3.h"
    // byte swapping routine
    #define SWAP_ENDIAN32(x) ((((uint_8*)&x)[0] << 24) | \
    (((uint_8*)&x)[1] << 16) | \
    (((uint_8*)&x)[2] << | \
    ((uint_8*)&x)[3])
    AC3_Bitstream::AC3_Bitstream(FILE *f)
    file = f;
    current_word = 0;
    bits_left = 0;
    total_bits_read = 0;
    done = FALSE;
    // preload data
    this->Load();
    AC3_Bitstream::~AC3_Bitstream()
    // Load data from file - does byte swapping
    int AC3_Bitstream::Load()
    int bytes_read = 0;
    if (file!=0){
    bytes_read = fread(&current_word,4,1,file);
    bytes_read = ( bytes_read << 2 ); /* multiply by 4 */
    current_word = SWAP_ENDIAN32(current_word);
    bits_left = bytes_read * 8;
    //FIXME finishing up the stream isn't done too gracefully
    if (bytes_read < 4){ // check to see if end of file
    done = TRUE;
    file = 0;
    return bytes_read;
    // Fetches 1-32 bits from the file opened in bitstream_open
    int AC3_Bitstream::GetBitSequence(uint_32 num_bits)
    uint_32 result;
    uint_32 bits_read;
    uint_32 bits_to_go;
    if(num_bits == 0)
    return 0;
    bits_read = num_bits > bits_left ? bits_left : num_bits;
    result = current_word >> (32 - bits_read);
    current_word <<= bits_read;
    bits_left -= bits_read;
    if(bits_left == 0){
    long loaded = Load();
    if (bits_read < num_bits) {
    bits_to_go = num_bits - bits_read;
    result <<= bits_to_go;
    result |= current_word >> (32 - bits_to_go);
    current_word <<= bits_to_go;
    bits_left -= bits_to_go;
    total_bits_read += num_bits;
    // crc_process(result,num_bits);
    return result;
    // Positions the stream pointer to a sync word
    int AC3_Bitstream::Resync() {
    int i = 0;
    uint_16 sync_word;
    if (!file) return -1;
    sync_word = GetBitSequence(16);
    /* Make sure we sync'ed */
    while(1) {
    if(sync_word == 0x0b77)
    break;
    sync_word = ( sync_word << 1 );
    sync_word |= GetBitSequence(1);
    i++;
    if (i > 32) { // fix added to handle EOF or closed files
    // printf( "EOF %d\n", ftell( bs->file ) );
    if ( ftell(file)==-1 || feof(file) ) {
    i = -1;
    break;
    total_bits_read = 16;
    // crc_init();
    return i; /* return # bits skipped */
    const uint_16 nfchans[] = {2,1,2,3,3,4,4,5};
    struct frmsize_s
    uint_16 bit_rate;
    uint_16 frm_size[3];
    const struct frmsize_s frmsizecod_tbl[] = {
    { 32 ,{64 ,69 ,96 } },
    { 32 ,{64 ,70 ,96 } },
    { 40 ,{80 ,87 ,120 } },
    { 40 ,{80 ,88 ,120 } },
    { 48 ,{96 ,104 ,144 } },
    { 48 ,{96 ,105 ,144 } },
    { 56 ,{112 ,121 ,168 } },
    { 56 ,{112 ,122 ,168 } },
    { 64 ,{128 ,139 ,192 } },
    { 64 ,{128 ,140 ,192 } },
    { 80 ,{160 ,174 ,240 } },
    { 80 ,{160 ,175 ,240 } },
    { 96 ,{192 ,208 ,288 } },
    { 96 ,{192 ,209 ,288 } },
    { 112 ,{224 ,243 ,336 } },
    { 112 ,{224 ,244 ,336 } },
    { 128 ,{256 ,278 ,384 } },
    { 128 ,{256 ,279 ,384 } },
    { 160 ,{320 ,348 ,480 } },
    { 160 ,{320 ,349 ,480 } },
    { 192 ,{384 ,417 ,576 } },
    { 192 ,{384 ,418 ,576 } },
    { 224 ,{448 ,487 ,672 } },
    { 224 ,{448 ,488 ,672 } },
    { 256 ,{512 ,557 ,768 } },
    { 256 ,{512 ,558 ,768 } },
    { 320 ,{640 ,696 ,960 } },
    { 320 ,{640 ,697 ,960 } },
    { 384 ,{768 ,835 ,1152 } },
    { 384 ,{768 ,836 ,1152 } },
    { 448 ,{896 ,975 ,1344 } },
    { 448 ,{896 ,976 ,1344 } },
    { 512 ,{1024 ,1114 ,1536 } },
    { 512 ,{1024 ,1115 ,1536 } },
    { 576 ,{1152 ,1253 ,1728 } },
    { 576 ,{1152 ,1254 ,1728 } },
    { 640 ,{1280 ,1393 ,1920 } },
    { 640 ,{1280 ,1394 ,1920 } }
    AudioSourceAC3::AudioSourceAC3(FILE *ac3File)
    // set the file ptr
    m_ac3File = ac3File;
    AudioSourceAC3::~AudioSourceAC3()
    // nothing
    BOOL AudioSourceAC3:arse(LPWAVEFORMATEX fmt)
    if (m_ac3File==0) {
    return FALSE;
    // create a bitstream
    m_ac3Bitstream = new AC3_Bitstream(m_ac3File);
    // sync to the start of an AC3 frame
    if (m_ac3Bitstream->Resync() < 0) {
    // unable to resync - clean up and return
    delete m_ac3Bitstream;
    return FALSE;
    // create sync info structure
    m_sync_info = new AC3_SYNCINFO();
    // and parse the sync_info
    ParseSyncInfo();
    // create the BSI
    m_bsi = new AC3_BSI();
    ParseBSI();
    fmt->wFormatTag = WAVE_FORMAT_DOLBY_AC3;
    fmt->nChannels = m_bsi->nfchans;
    switch (m_sync_info->fscod) {
    case 2:
    fmt->nSamplesPerSec = 32000;
    break;
    case 1:
    fmt->nSamplesPerSec = 44100;
    break;
    case 0:
    fmt->nSamplesPerSec = 48000;
    break;
    default:
    fmt->nSamplesPerSec = 0;
    break;
    fmt->nAvgBytesPerSec = (1000 * m_sync_info->bit_rate) / 8;
    fmt->nBlockAlign = 1;
    fmt->wBitsPerSample = 0;
    fmt->cbSize = sizeof(WAVEFORMATEX);
    delete m_bsi;
    delete m_sync_info;
    return TRUE;
    // Parse a syncinfo structure, minus the sync word
    void AudioSourceAC3:arseSyncInfo()
    /* Get crc1 - we don't actually use this data though */
    m_ac3Bitstream->GetBitSequence(16);
    /* Get the sampling rate */
    m_sync_info->fscod = m_ac3Bitstream->GetBitSequence(2);
    /* Get the frame size code */
    m_sync_info->frmsizecod = m_ac3Bitstream->GetBitSequence(6);
    m_sync_info->bit_rate = frmsizecod_tbl[m_sync_info->frmsizecod].bit_rate;
    m_sync_info->frame_size = frmsizecod_tbl[m_sync_info->frmsizecod].frm_size[m_sync_info->fscod];
    // stats_printf_syncinfo(syncinfo);
    void AudioSourceAC3:arseBSI()
    uint_32 i;
    /* Check the AC-3 version number */
    m_bsi->bsid = m_ac3Bitstream->GetBitSequence(5);
    /* Get the audio service provided by the steram */
    m_bsi->bsmod = m_ac3Bitstream->GetBitSequence(3);
    /* Get the audio coding mode (ie how many channels)*/
    m_bsi->acmod = m_ac3Bitstream->GetBitSequence(3);
    /* Predecode the number of full bandwidth channels as we use this
    * number a lot */
    m_bsi->nfchans = nfchans[m_bsi->acmod];
    /* If it is in use, get the centre channel mix level */
    if ((m_bsi->acmod & 0x1) && (m_bsi->acmod != 0x1))
    m_bsi->cmixlev = m_ac3Bitstream->GetBitSequence(2);
    /* If it is in use, get the surround channel mix level */
    if (m_bsi->acmod & 0x4)
    m_bsi->surmixlev = m_ac3Bitstream->GetBitSequence(2);
    /* Get the dolby surround mode if in 2/0 mode */
    if(m_bsi->acmod == 0x2)
    m_bsi->dsurmod= m_ac3Bitstream->GetBitSequence(2);
    /* Is the low frequency effects channel on? */
    m_bsi->lfeon = m_ac3Bitstream->GetBitSequence(1);
    /* Get the dialogue normalization level */
    m_bsi->dialnorm = m_ac3Bitstream->GetBitSequence(5);
    /* Does compression gain exist? */
    m_bsi->compre = m_ac3Bitstream->GetBitSequence(1);
    if (m_bsi->compre) {
    /* Get compression gain */
    m_bsi->compr = m_ac3Bitstream->GetBitSequence(;
    /* Does language code exist? */
    m_bsi->langcode = m_ac3Bitstream->GetBitSequence(1);
    if (m_bsi->langcode) {
    /* Get langauge code */
    m_bsi->langcod = m_ac3Bitstream->GetBitSequence(;
    /* Does audio production info exist? */
    m_bsi->audprodie = m_ac3Bitstream->GetBitSequence(1);
    if (m_bsi->audprodie) {
    /* Get mix level */
    m_bsi->mixlevel = m_ac3Bitstream->GetBitSequence(5);
    /* Get room type */
    m_bsi->roomtyp = m_ac3Bitstream->GetBitSequence(2);
    /* If we're in dual mono mode then get some extra info */
    if (m_bsi->acmod ==0) {
    /* Get the dialogue normalization level two */
    m_bsi->dialnorm2 = m_ac3Bitstream->GetBitSequence(5);
    /* Does compression gain two exist? */
    m_bsi->compr2e = m_ac3Bitstream->GetBitSequence(1);
    if (m_bsi->compr2e) {
    /* Get compression gain two */
    m_bsi->compr2 = m_ac3Bitstream->GetBitSequence(;
    /* Does language code two exist? */
    m_bsi->langcod2e = m_ac3Bitstream->GetBitSequence(1);
    if (m_bsi->langcod2e) {
    /* Get langauge code two */
    m_bsi->langcod2 = m_ac3Bitstream->GetBitSequence(;
    /* Does audio production info two exist? */
    m_bsi->audprodi2e = m_ac3Bitstream->GetBitSequence(1);
    if (m_bsi->audprodi2e) {
    /* Get mix level two */
    m_bsi->mixlevel2 = m_ac3Bitstream->GetBitSequence(5);
    /* Get room type two */
    m_bsi->roomtyp2 = m_ac3Bitstream->GetBitSequence(2);
    /* Get the copyright bit */
    m_bsi->copyrightb = m_ac3Bitstream->GetBitSequence(1);
    /* Get the original bit */
    m_bsi->origbs = m_ac3Bitstream->GetBitSequence(1);
    /* Does timecode one exist? */
    m_bsi->timecod1e = m_ac3Bitstream->GetBitSequence(1);
    if(m_bsi->timecod1e) {
    m_bsi->timecod1 = m_ac3Bitstream->GetBitSequence(14);
    /* Does timecode two exist? */
    m_bsi->timecod2e = m_ac3Bitstream->GetBitSequence(1);
    if(m_bsi->timecod2e) {
    m_bsi->timecod2 = m_ac3Bitstream->GetBitSequence(14);
    /* Does addition info exist? */
    m_bsi->addbsie = m_ac3Bitstream->GetBitSequence(1);
    if(m_bsi->addbsie) {
    /* Get how much info is there */
    m_bsi->addbsil = m_ac3Bitstream->GetBitSequence(6);
    /* Get the additional info */
    for(i=0;i<(m_bsi->addbsil + 1);i++)
    m_bsi->addbsi[i] = m_ac3Bitstream->GetBitSequence(;
    // stats_printf_bsi(bsi);
    Greatings from Hans.
    Feb 2001
    Berlin, Germany
    Seems to be a log file? Sorry, I never used nandub.
    If you have a divx with AC3 sound, you need to install the proper divx codec and a AC3 codec.
    You can use this one: http://www.doom9.org/Soft21/Files/Audio/ac3dec.zip
    Copy the .ax file to windows\system.
    Register the filter as follows:
    c:\windows\system>regsvr32 ac3dec.ax
  5. Thanks for helping me out.
