ok, im new here and looked in the other topics, so if this has been posted before or if i'm in the wrong forum just let me know. i have Mainconcept MPEG Encoder and TMPGEnc DVD Author. no matter how hard i try i cant find out how to get my avi file to fit on the screen after i burn it. i try all the allowed sizes and it wont fit 100%. ive even tried 16:9 ratio. am i just out of luck? i only care because what im burning has subtitles and i cant read 100% of them when theyre burned and im sick of wasting blank dvds.
second, how do i compress the files so they are smaller? i can only burn 2 hours worth of avis, and i know their must be a way to make the files smaller. help! thanks.
use dvd+-rws.
and add black borders with mainconcept,under details->crop and scale and scale down it a bit.
and lower the bitrate to make smaller mpegs, under details->advanced-> bitrate.
and read the included help.
i tried the borders but it covered up the subtitles even over, like the black overlapped. is there a way to add borders so it doesnt cover up part of the video? thanks.
scale doesn't remove anything. didn't you use the crop function???
Quick question on quality and file size...
By rxloren in forum Newbie / General discussionsReplies: 3Last Post: 28th Oct 2010, 20:26 -
Reduce file size vs. compression question. Am I doing this right?
By Ronny G in forum Authoring (DVD)Replies: 9Last Post: 29th Dec 2008, 09:30 -
Quick compression size question.
By capman21 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Dec 2008, 21:35 -
DTV converter box, screen size-related question
By Ai Haibara in forum DVB / IPTVReplies: 6Last Post: 22nd Nov 2008, 19:18 -
16:9 Screen Size Question
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 10th Sep 2007, 19:43
