OK, I accomplished getting my movie onto my computer (iBook G4) via USBVision Capture. No I want to put it onto a DVD which is playable on my DVD player. I am able to export the movie into the following formats: 3G, avi, bmp, dv stream, flc, hinted movie, image sequence, quicktime movie, quicktime media link and mpeg-4.
Using the above-mentioned, how do I burn a DVD with my movie that is playable on my DVD player?
I do have Toast 6, iMovie, DVDzoneX.
Make it simple please...thanks
keep the rubber side down
Originally Posted by tttman
USBVision is a 352X240 30fps format that is a compressed QuickTime file. EchoFX sells it to work with the old xlr8 Interview capture device and other USB video capture units. A "USBVision.component" is placed in the Libraries>QuickTime folder so that QuickTime can play the movies. The software includes an exporter that converts a USBVision file similarly to choosing Export from QuickTime Pro.
Because Toast uses the QuickTime codecs, there is a fair chance that dragging the USBVision file directly to the Toast Video tab could work without any export. Certainly worth a try.
Question about transferring a MAcrovisioned VHS tape to DVD
By goodsmartman in forum DVD & Blu-ray RecordersReplies: 4Last Post: 29th Sep 2011, 20:21 -
Question: Long horizontal scratches on VHS tape
By bisonrav in forum RestorationReplies: 12Last Post: 6th Mar 2010, 07:09 -
Question about capturing VHS tape to .avi file
By rfdillon in forum Capturing and VCRReplies: 6Last Post: 27th Jul 2008, 00:44 -
making a DVD from an old Video camera tape
By oreocharlie in forum Authoring (DVD)Replies: 5Last Post: 17th Dec 2007, 13:39 -
old VHS tape making vcr heads dirty
By abbymat in forum RestorationReplies: 7Last Post: 16th Aug 2007, 06:33
