For the longest time i have been using apple disc's but recently i tried memorex dvd's, and almost everytime i try to burn a dvd, i get a hardware error. I am wondering if this is a common problem with memorex disc's or something with Toast6? I am using a powerbook G4 with a combo drive.
I've used Memorex a number of times w/out any problems on my superdrive, and they should be a reputable brand too. I'd say check your updates and use disk utilities and repair permissions and post back your results- Good luck!
"What's a matter Colonel Sanders???? CHICKEN???!!!! -
Well, the problem has not gotten any better. I am about use about 3 dvd's per movie. But i believe my problem is that i have never updated my toast 6. And the dvd's came with a warning that i needed to make sure the software and i had was compatable with at least 4x downloads. but i am not positive, because i have used the apple 4x before without a problem.
Memorex media comes from many sources and is not consistently reliable. One spool can have good results and another poor results.
This is true, but usually I haven't had any problems with them- there is website that explains this... don't remember what it is, but if anyone does post it for him
(the one that tells what grade dvds are and what companies buy these disks... wait- www.nomorecoasters.com)
Give this webpage a look and make up your mind for yourself
Peace-
audio problems when burning a DVD
By cosypete in forum Authoring (DVD)Replies: 3Last Post: 9th May 2010, 18:23 -
Problems with DVD burning for backup
By DDieggo1000 in forum Newbie / General discussionsReplies: 3Last Post: 2nd Jul 2009, 23:36 -
DVD burning problems
By Tbag in forum ComputerReplies: 13Last Post: 3rd Sep 2008, 15:55 -
DVD download Burning problems
By completeidiot in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 05:53 -
By ssaamm in forum DVD & Blu-ray WritersReplies: 10Last Post: 22nd Sep 2007, 00:11
