Ok. I bought a capture card and it works when i plug my cable tv directly into the capture card but if i run a cable from the vcr to the capture card it wont show. i think it has something to do with the s-video or something like that..any ideas i would appreciate it. thanks
Does your capture card have a setup screen where you can select the input source?
Did you try switching your vcr to TV?
y'know, the little tv/vcr switch thingy? -
You need to select what input your using in your capture card configuration. cable/s-video/composite Cable works because that is probably the default.
Hi8 capture- Suggestions for Harddrives and Capture Cards?
By CMP1223 in forum Capturing and VCRReplies: 7Last Post: 11th Jun 2011, 00:05 -
capture cards 360
By ihazcheezburga in forum Capturing and VCRReplies: 2Last Post: 19th Feb 2011, 20:14 -
What's new in capture cards for VHS capture?
By chowmein in forum Capturing and VCRReplies: 21Last Post: 29th Jul 2010, 09:03 -
Using 2 Hauppauge Capture Cards
By ddpool58 in forum Capturing and VCRReplies: 35Last Post: 21st Aug 2009, 22:53 -
Interferance on capture cards
By Signal in forum Capturing and VCRReplies: 35Last Post: 13th Sep 2007, 22:26
