  1. I burnt a movie with NEC dual format drive using NERO 6.(Nero says burn process was successful.) Now I can`t play in Power DVD, it says "unsupported file format in drive G". My Daewoo DVD player shows "NO DISK". What can I do, please help?!
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    About the only thing I can think of is did you FINALIZE the disc? If not then nothing will read it except nero. If you did then maybe it's the media. Try it again with a different brand disc (and sign: maybe your regular dvd player likes +vs-r or vice versa). Those are about the only suggestions I can make. Good luck.
    Kevin
  3. I used an +RW disk as I did before. The NEC burner has just been installed.I do everything as I did before with my HP 200i when everything worked fine.. I don`t know what I should adjust.
