    Apr 2003
    Hi i have been coverting some mpg files to be burnt to dvd disk,
    i have been using this guide to do it http://www.donstevenson.net/myguides/myguides.html
    sadly due to not having enough space on a disk i had to convert the files into 3 seperate folders is there anyway that i can merge the 3 folders together to be placed on 1 disk?
    Apr 2003
    forgot to add that the folders that have been created contain Audio/Video TS folders and within those are VOB, IFO and BUP files.
    If any1 needs anymore info to help me please ask as i would really like to be able to get all these files on 1 DVD if possible
  3. you could use DVD2one,and "join" them in it.
    then it would be like(it doesnt have to be,mind) 1 dvd movie with 3 chapters.
    **i dont know if you already made chapters for the original files,but anyways,if they do,then just substitute "3" for whatever the number is.
    each section would have multiple chapters then,it would just either be a "seamless join" between parts,1 2, and 3 with each having a certain number of chapters in them.
    or you could still join them with this programme,and have 3titles on the dvd,like 3 movies seperatly,pickable with the title button on the remote for your standalone.
    tmpgenc dvd author, add dvd video.
    Apr 2003
    I did originally try encoding them all at once but i recived a warning saying that the file was too big for a 1 dvd so i didn't carry on encoding
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    You can Ignore this warning and DVDShrink or DVD2One the output, or re-encode the files to lesser bitrates before you start.
    If in doubt, Google it.
    Apr 2003
    when i recived the warning i wasnt allowed to carry on
    Apr 2003
    I have now shrunk the files now so that they will all fit on 1 dvd but what should i use to burn the 3 seperate video_ts.ifo files onto 1 disk
