i am using ulead dvd moviefactory 2 to convert my 23fps to 29fps mpeg so it'll be compliant with my dvd player. when i convert it to a vcd the quality just decreases. is there a better way to do this w/o losing much quality.
Computer Spec:
winxp pro, 2.4ghz, 768mb ram, 100gb -
Don't use Ulead MF to do your conversion. Pick a top qlty converter. Mainconcept MPEG Encoder has been nice to me.
i do use tmpgenc but whenever i want to convert a 23fps mpeg to a 29fps mpeg i would always encounter problems. mainly 2 problem
1. voice out of sync
2. it will start to convert fine but like near the middle it will just studden stop.
i 'll try that other program that was suggested. thanks.Computer Spec:
why are you trying to convert from 23 to 29fps? the videocd (ntsc film) template is a 23fps VideoCD. shouldnt have problems b/c of that.
is a 2 part movie. i want to convert it to 29fps so i can add it to tmpengc dvd author so i can make a dvd.
Computer Spec:
TMPEGEnc should be your program to use, it's one of the best choices to encode to a VCD.
Converting AVI to DVD using DVD Flick: low quality result
By e2p in forum Video ConversionReplies: 13Last Post: 28th Oct 2010, 11:50 -
Does Converting MPEG1 2 MPEG 2 improve quality?
By purpleronnie in forum RestorationReplies: 10Last Post: 7th Aug 2009, 16:47 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 03:18 -
converting down to low size yet maintain good quality
By lawlbear in forum Video ConversionReplies: 3Last Post: 19th Dec 2008, 19:06 -
Improving quality of mpeg before converting to dvd...
By AshleyQuick in forum Newbie / General discussionsReplies: 4Last Post: 28th Apr 2008, 15:41
