I have always had problems (Audio Sync) w/ DVD-Lab when making my home videos into DVDs. Recently I discovered that it is being caused when I use MPEG-VCR to join 2 videos from different captured tapes. If I use MPEG-VCR only to remove unwanted parts from a single video it works though. So my question is , how is that possible? and is there a way to avoid that? Both tape videos are MPEG2 3.9 - 4mb/s VBR - 256k MPEG2 audio. And after the editing,, the computer plays fine except once I compile a dvd from the videos. Weird no? I rather be able to join them so that I don't have to create extra menus for each video within the dvd and can fit most footage into a DVD.
I thank you guys for your support in advance![]()
Results 1 to 1 of 1
you have open GOPs says dvd lab
By sumeshkri in forum Video ConversionReplies: 1Last Post: 11th Jun 2010, 05:50 -
Upsides/downsides to open GOPs
By dadrab in forum Video ConversionReplies: 16Last Post: 6th Mar 2008, 21:53 -
Close GOPs
By Ar'ina in forum Authoring (DVD)Replies: 5Last Post: 23rd Dec 2007, 04:22 -
How to actually close "open GOPs" abd avoid warning with DVD Lab
By perfection in forum Authoring (DVD)Replies: 1Last Post: 1st Sep 2007, 00:42
