I am wondering if it is possible to enlarge a DVD-sequence say x2 times. Then I would like to merge this sequence with other DVD-movie sequences and burn the merged sequences to a DVD.
My stand alone DVD-player has a Enlarge function, so I guess it must also be possible to edit sequences of a DVD-movie by enlarging.
But how do you do it?
I know how to merge sequences and to burn the DVD.
What I am wondering is what MPEG-editor/function I would need in order to enlarge this sequence x2. I am currently using DVD-Shrink to extract the desired sequence from the full DVD-movie.
/Bieurn
Do you mean you want to increase the resolution of the video 2x? (720x480 to 1440x960 for example?)
Why would you want to do this? You won't get that much increase in quality and you would only be able to play it back with a beefy computer, at which point the advantages of this sort of thing make more sense to do in postprocessing (via ffDshow).
But if you still want to do it open the .d2v file in something like virtualdubmod (or better with AVIsynth framserved to virtualdubmod.) You can either resize with vdubmods resize filter or you can resize it in AVIsynth (better)
-Suntan
***HELP*** Needed Enlarging Resolution & Format of Video Clip!
By therock09wbt in forum EditingReplies: 2Last Post: 30th Dec 2010, 17:31 -
DVD scenes jumping out of sequence
By click50 in forum Newbie / General discussionsReplies: 4Last Post: 8th Dec 2009, 00:38 -
Convert DVD to JPG sequence by any second interval?
By omega_weapon in forum EditingReplies: 3Last Post: 29th Jan 2009, 17:01 -
Image sequence to HD 1080 DVD? Lots of questions, please help!
By rayrayray in forum Video ConversionReplies: 5Last Post: 27th Jul 2007, 12:43 -
Enlarging and restoring video
By Crac59 in forum Newbie / General discussionsReplies: 2Last Post: 30th May 2007, 18:36
