Hi just a few problems I am having.
First is that I have a pinnacle pctv tuner card and I am trying to play a vhs video on the pc, I can get sound but no picture.
Second is that I have got a few movies on the hard drive and have been playing the ts file in windows media player, I can get the picture but no
sound.
I am running windows xp home edition.
Pentium 4 3.06ghz
768mb ram
240gb hdd
64mb nvidia video card
I have no codecs installed and not sure if I need any to make my problems go away and if I do what codecs do I need.
Ok I have downloaded the 3divx codec and now I get picture when playing
a video on the pc.
But I still dont get any sound when playing a movie in windows media player.
The movie is one I backed up using dvdshrink, and I doubleclick on the tsfile to play in WMP. It plays the movie fine, I get picture but no sound. -
Hello,
Have you tried ac3filter?? That might help a bit. Are they encoded in 5.1? You might need a dolby digital plug in for windows media player.
Kevin
P.S. As you found out you need SOME kind of codec installed to play any audio/video file. They are what the computer needs to READ the file.
Most likley you haven't selected which input you are using. You need to select between tuner/composite/s-video (or whatever inputs there are) in the capture card configuration.Originally Posted by aussie8964
I dunno, try playing it with another player like powerDVD. If the files are DVD compliant which they should be, you should have sound.Originally Posted by aussie8964
You do unless you uninstalled them, the need to install a codec is rare. This will occur when you get a movie that was created by someone else using a specific codec. The player should give you an error stating that it can't find the codec. Look in the tools section, there's aps for determining what codec is used for a file and the most common codecs. Some codecs are propietary and have to be purchased.Originally Posted by aussie8964 -
Hello,
Good point. I'd like to add one thing to that. I use the wintv pvr250 and it only has a svideo input jack. It comes with a rca-svideo adapter. In order to get the picture I need to select svideo+composite combo option (ie they're listed together on the same line in the menu). This might be part of your problem.thecoalman-Most likley you haven't selected which input you are using. You need to select between tuner/composite/s-video (or whatever inputs there are) in the capture card configuration.
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
[Sony Vegas 9] Problem with Picture-in-Picture (Track Motion)
By BramJ in forum EditingReplies: 1Last Post: 27th Jan 2010, 04:52 -
Avisynth Picture in Picture Script Slows Down Video and Lacks Sound
By OpNash in forum EditingReplies: 2Last Post: 26th Nov 2008, 20:00 -
Sound but no Picture?
By Soulfinger in forum Newbie / General discussionsReplies: 4Last Post: 13th Mar 2008, 18:10 -
I have sound, but no picture?
By TSI_AWD in forum Newbie / General discussionsReplies: 1Last Post: 9th Nov 2007, 10:59 -
No sound but picture works
By tou in forum MacReplies: 6Last Post: 12th Oct 2007, 17:36
