I'm backing up a DVD, using DVD Shrink 3.2. About halfway through the process, I get a popup dialogue box with this error "DVD Shrink encountered an error and cannot continue. Failed to read drive E:\. Data error - cyclic redundancy check."
Any suggestions as to what might be causing this? Any fixes?
Thanks!
Just getting my feet wet!
Clean the disc. There are probably other causes of that error, but every single time I've encountered it, I've cleaned the disc and not had a problem.
Rip with DVD DECRYPTER in FILE MODE first then use DVD SHRINK 3.2 to compress.
__________________________________________________ ___________
What are the advantages of File Mode over ISO mode?
Nothing can stop me now, 'cause I don't care anymore. -
Thank you thinger62! I never thought of looking at the disc itself and sure enough, it was smudgy. I cleaned it and was able to back it up with no problem. Thanks a lot for the suggestion!
Just getting my feet wet! -
I only use ISO MODE when the dvd movie is single layer (dvd5). No compression is needed so rip in ISO MODE then burn with DVD DECRYPTER.
Dvd Shrink Gives me and error?
By mrjust in forum Newbie / General discussionsReplies: 4Last Post: 12th Jun 2010, 19:05 -
DVD Shrink 3.2 .IFO Error
By michpearl in forum Newbie / General discussionsReplies: 4Last Post: 11th Jun 2010, 23:02 -
DVD Shrink Error: Programing Error, exception occurred
By lapetite_66 in forum DVD RippingReplies: 5Last Post: 2nd Jun 2010, 15:59 -
dvd shrink reauthor error
By victoriabears in forum Newbie / General discussionsReplies: 1Last Post: 16th Jan 2010, 15:09 -
Error when trying to shrink DVD files
By bambam in forum DVD RippingReplies: 10Last Post: 9th Jul 2007, 11:54
