Does anybody have a tutorial or guide that I can follow to put several avi (xvid) files to dvd? I have tmpgenc plus 2.5 and tmpgenc author already. I can't seem to get anywhere with the tutorials that I've been reading because they all seem to support putting a single avi file to dvd.
All advice is greatly appreciated.
I would suggest you go through the guides you have for putting one file to DVD, then after you have added the clip to a track in TMPGEnc DVD Author, either save the layout you have set up in TMPGEnc DVD Author or just leave it open. Go back and start the guide again with your next clip. Again, once you have added this clip to your existing layout, start the guide again until you have added all your clips to the track layout.Originally Posted by brtecson
One thing to remember is that if you add multiple clips to the one track, they will act as chapters and continuously play through each one until the entire track has been played. If you want the DVD to play each clip then return to the menu, make a new track each time you add a new clip, and make sure that there is only one clip in each track.If in doubt, Google it.
merge multiple avi to 1 single file
By carlos28355 in forum Newbie / General discussionsReplies: 16Last Post: 2nd Oct 2010, 20:11 -
Multiple Titles In A DVD ISO To A Single AVI
By Simmons in forum Video ConversionReplies: 1Last Post: 9th Aug 2010, 01:32 -
Multiple VCD to single DVD
By Ryan Kelly in forum MacReplies: 7Last Post: 5th Apr 2009, 12:15 -
Can you set alltoavi to produce a single AVI from multiple VOBs?
By benvid in forum Newbie / General discussionsReplies: 0Last Post: 18th Oct 2008, 12:25 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 13:49
