I use Xvid in single pass Quantizer mode, Q=2 or 3.Originally Posted by supergoku
Results 31 to 45 of 45
Oooooooh, it's fixed!
I can't wait to try it out.
--edit--
Yes indeed, it seems to work great now. Thanks Wilbert!
is there a way to do this with Realvideo that is 24 fps? i am converting it to avi to play in the philips.
Just set the fps= argument to 24, or more likely 23.976. I made separate templates for 23.976 and 29.97.Originally Posted by hddvd2
i don't get that partOriginally Posted by gastorgrab
can i use this method to add the subs to the videos file at the same time too?[/quote] -
Yes, use the AVISynth template to open the file in VirtualDubMod. Use the regular sub filters to add the subtitles.can i use this method to add the subs to the videos file at the same time too?
junkmalle: yes, i did as what you you said(i converted a *.rmvb file into an *.avi file) but the file turns out to be really big that my harddisk can not handle, do you know why?
You probably saved as an uncompressed RGB AVI. Use Video -> Compresssion... to select a codec (Xvid?) and bitrate.
can anyone help me with this? everytime i try to make this rmvb to avi it ran out of space
It sounds like you didn't choose a video codec to compress your output video. (or you have a really small hard drive)Originally Posted by annabutt
Some links for you guys!
SPAM
You are in breach of the forum rules and are being banned for spamming.
/ Moderator mats.hogberg -
Is the RealMedia Splitter supposed to work with video and audio, or just audio?
All of the above. Audio/Video, just Audio, or just Video.
RealMedia Splitter is a Directshow filter that allows your PC to play RealMedia (a source filter) AND to split a RealMedia package into two streams (Audio/Video) for playback.
hi, i tried out ur virtualdubmod guide and it worked out fine, except that it alwis hangs when i try to open a avs file.
but i had this audio synth problem, i tried ur method and it cant work so i tried reinstalling all my codecs and programs, but now when i try to open a avs file, this error pops up:
Avisynth open failure:
Script error: there is no function named "directshowsource"
(C:\abc.avs, line 1)
this is wad i put in my avs file
DirectShowSource("17.rmvb", fps=23.976, convertfps=true)
any idea whats causing the error??
to add on, i can open my avs file using the AuxSetup.exe, and click open virtualdubmod
but when im into the steam list, i cant see any formats of the bitrats for MP3 lame and MPEG3
help~~~~~~~~~~~~~~
Handling 4:3 PC video on 16:9 TV
By ptrk.mj in forum Newbie / General discussionsReplies: 14Last Post: 20th Dec 2010, 13:30 -
Handling home made HD recordings
By ngc7088 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 11th Mar 2010, 17:03 -
More Video Source Handling Questions..
By alcOre in forum Newbie / General discussionsReplies: 21Last Post: 11th Mar 2009, 03:00 -
Best error handling
By demonwarrior in forum DVD & Blu-ray WritersReplies: 5Last Post: 11th Sep 2007, 03:16 -
TDA3..Audio Handling
By barneystorm in forum Authoring (DVD)Replies: 1Last Post: 19th Jun 2007, 21:01
, thank you very much
