right now i am using the trial version of most ofthe softwares, i am a beginner. 1rst , i would like to know on which of the softwares and best ones to purchase. 2nd , do i absolutely need a capture card , if so which is the best to go with . 3rd , right now i am using the trial version of tmpegnc to encode the clipsto mpeg 2 and then using sonic my dvd to author and burn......is this way ok ! or not .......
Results 1 to 11 of 11
Two question's for you.....
Just what are you trying to do ????
Just what do you want to do ????Not bothered by small problems...
Spend a night alone with a mosquito -
to burn movies........one more thing , right nowe when i burn something it;s a little to big for my tv screen , when i play it. is therte some where were i can fix this.
A little more info would be nice, but here goes. Do yourself a favor and drop-kick Sonic MyDVD into a dumpster. It's nothing but trouble, IMHO. Get a good free authoring program (look in the tools section) or pay for something decent, but inexpensive like Ulead DVD Movie Factory.
Keep TMPGEnc. -
Sometimes I have beer & nachos when I watch DVDs.
If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
i still can not seam to get my picture very clear or sometimes its a bit to bright after i burn my movie on dvd and play it in my dvd player to watch on tv. is there any way of settinng up somrthing so it fixes these problems aoutomaticaly. any ibfo would be great. i am, using tmpegnc and unlead dvd movie factory .
You may have to open it in an editor and tweak it there. Do you have an editing app?
ou can open the MPEG file, cut out unwanted stuff, change the audio format, change the video format, add scene fades - almost anything. Then you save it as an MPEG. Check them out in the tools section.Originally Posted by spiderman03
does the program ulead dvd movie factor do the athoring before burning or do i need another program for that.
3d questions
By alucard2050 in forum DVB / IPTVReplies: 16Last Post: 22nd Aug 2010, 00:01 -
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 16:50 -
Powersupply questions and fan questions
By yoda313 in forum ComputerReplies: 39Last Post: 8th Sep 2008, 19:08 -
Some Yes or No questions
By the_importer in forum Media Center PC / MediaCentersReplies: 22Last Post: 3rd Jul 2008, 19:06 -
Got a new 16:9 TV, have some questions...
By sdsumike619 in forum Video ConversionReplies: 6Last Post: 28th Jul 2007, 15:00
