I have been capturing TV broadcasts with the Pinnacle PCTV deluxe. Lots of problems with the device, but once you make it work, captures were excellent.
I was capturing interlaced, Top Field First at a high bitrate and then after editing re-encoded to MPEG2 at TTF and interlaced. DVDs worked out fine.
Unfortunatelly, the device broke, so I reverted to my ASUS ViVo card and Mainconcept capture.
Again, I captured interlaced, Top Field First and continued the process in the same way.
However, DVD playback was flickering. The bottom 1/3rd of the frame was flickering while the camera was panning.
I tried to re-encode to MPEG-2 with Bottom Field First. Again the same result, although now the top 1/3rd of the frame had flicker while panning in the same parts of the movie.
I then tried to de-interlace with VirtualDUB and re-encode to MPEG-2 as progressive.
This time, the playback on the DVD player was almost perfect. Not as good as my previous interlace captures-interlace encodings but certainly viewable.
Can anyone give any idea as to why this is happening?
Again
The more I learn, the more I come to realize how little it is I know.
Nobody seems to have any comment on the issue.
I have tried the capture with Mainconept doing the de-interlace during capturing, and the result is much better than VirtualdUB de-interlace, however movie movement is still inferior to the original broadcast or the Pinnacle capture.
I also tried to capture with VirtualDUB using hufyuv. After MPEG2 encoding and authoring, the results are the same. Interlaced captrure playback causes severe flickering on the TV.
So, I guess I have a more generic problem than Mainconcept capture.
Any ideas or suggestions?The more I learn, the more I come to realize how little it is I know.
Strange subtitle issue w/Ripbot
By Rod419 in forum Blu-ray RippingReplies: 2Last Post: 28th Nov 2011, 06:17 -
Strange issue with VOB
By idlebrain1 in forum Video ConversionReplies: 1Last Post: 20th May 2010, 16:12 -
Help with a strange issue in authoring AVCHD
By malikidrees in forum Authoring (Blu-ray)Replies: 2Last Post: 13th Mar 2010, 16:07 -
VHS to DVD, resulting interlace issue on television
By Sawood in forum Authoring (DVD)Replies: 6Last Post: 8th Apr 2008, 13:08 -
Strange audio size issue.
By mijman in forum DVD RippingReplies: 1Last Post: 16th Jan 2008, 08:42
