Okay this is kinda a quick question.
I have an mpeg2 file and wanna put it into svcd disc with nero, I chose Super Video CD but which folder do I put the mpeg file into?
and which folder for the mepg1 file with an VCD?
Thx
I just use the Nero Wizard, select Other Formats, select Video CD, then drag the MPG file into Nero, start the burn, and Nero magically does the rest for me. The resulting CD has a bunch of folders and files in them even though I only supplied the MPG. Seems to play fine on my PC though I have no way of trying to play it on a hardware player.
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 12:59 -
Burning SVCD At 480 x 272, 1152 kbps ?
By Tham in forum Authoring (VCD/SVCD)Replies: 2Last Post: 16th Sep 2010, 15:21 -
Svcd Burning
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 16th Apr 2008, 09:25 -
Burning vcd/svcd full length film.........
By marcgarcia in forum Authoring (VCD/SVCD)Replies: 2Last Post: 15th Oct 2007, 21:07 -
Burning SVCD to a DVD (Not converting!)
By bebopdeluxe in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2007, 10:06
