Heres the situation.
I have converted my Home Movie DV streams into fully compliant DVD streams. Is it possible to simply copy the Video_TS folder onto a standard CD* and have it work in a standalone DVD player?
*I do not have a DVD writer.
That would be called a Mini-DVD, or cDVD. If you do a search through the dvd player list on this site you can see which DVD players can play this very non-standard format. Unfortunately I can probably count the players on one hand.
You may have to break down and buy a DVD writer to get hardware playback of your movies. Either that or you'll have to convert to one of the more supported CD based formats like VCD or SVCD. -
Thanks adam, much appreciated. *thumbs up*
I have a Philips 634 and the DVD list says that MiniDVD hasnt been tested. I shall try that later.
If that doesnt work, i shall try compiling a DATA CD in Nero and burning the VOB's to it- I read a review that said that worked
Problem converting from MPEG Program Stream to Transport Stream
By vivajam in forum Newbie / General discussionsReplies: 5Last Post: 24th Jan 2011, 05:40 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 18:12 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
Author TS Stream to Blu Ray - Always need to be re-encoded?
By steve99999 in forum Authoring (Blu-ray)Replies: 12Last Post: 16th Aug 2009, 07:12 -
TMPGenc DVD Author 3 issues "No stream available" Error Code 0x80
By newsletters in forum Video ConversionReplies: 0Last Post: 8th Oct 2007, 18:20
