A quick question for now.
In advanced user settings (cce customized settings), which value is best for VBR_Bias? My default value is 25, but when looking at the doom-9 guide, their value is set at 10. Which is best?
As well, Quality_Prec. Mine is default16, but doom-9 is 24.
I set the number of passes to 3.
Doom-9.org does not state to change the VBR_Bias, nor Quality_Prec, so what should I do?
Thanks!
set it to 1 pas vbr (CQ) instead, if you want to mess with those adjustments --
read your manual"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
you must be refering then to an older version of CCE sp , which is not supported by cinema craft ,
please update to the current version and go through your manual ..
if you have problems upgrading , i can forward your email to your dealer , who you purchased cce from and they would be happy to help you ..
omni
OMNI DVD MEDIA (North America)
TEL : +1-714-734-8900
e-mail : omni@cinemacraft.com
Open Video Systems
Open Video Systems, LLC (North America)
TEL : +1-310-930-7219
e-mail : Sales@OVS-TV.com
visible light
TEL : +1-407-327-5700"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
New to Blu-ray but experienced video editer
By Derekfoxes in forum Authoring (Blu-ray)Replies: 21Last Post: 31st Aug 2011, 16:15 -
Question for experienced ISOBuster user
By jman98 in forum Newbie / General discussionsReplies: 14Last Post: 15th Apr 2010, 19:44 -
Anybody experienced with ADVC-300 use ?
By Tafflad in forum Newbie / General discussionsReplies: 6Last Post: 8th Dec 2009, 03:33 -
DV - avisynth - x264 your experienced thoughts
By doggyjumper in forum Video ConversionReplies: 0Last Post: 29th Aug 2008, 13:41
