Hello,
I have a new problem with this great FfmpegX application.
I already made some DVD Hi-Bitrate with FfmpegX0.0.9L
The file was a 3ivx with MPEG-4 sound.
I tryed again 2 or 3 times with the new version (0.0.9m)
Apparently I have a problem with the sound. ffmpegX can't encode the sound. It is the same files that I converted succesfully to DVD 1 month ago.
here the info :
Encoding started on Fri Jul 23 12:45:34 CEST 2004
-f 5 -b 4000 -q 3 -B 260 -V 230 -a 2
-F 1
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
MPlayer dev-CVS-040718-22:40-3.3 (C) 2000-2004 MPlayer Team
AltiVec found
CPU: PowerPC
Reading config file /usr/local/etc/mplayer/mplayer.confReading config file /var/root/.mplayer/config
Reading /var/root/.mplayer/codecs.conf: Reading /usr/local/etc/mplayer/codecs.conf: Using built-in default codecs.conf.
: No such file or directory
Can't open '/var/root/.mplayer/codecs.conf': No such file or directory
Can't open '/usr/local/etc/mplayer/codecs.conf': No such file or directory
ar/root/Desktop/file.srt'
init_freetype
get_path('font/font.desc') -> '/var/root/.mplayer/font/font.desc'
font: can't open file: /var/root/.mplayer/font/font.desc
Font /usr/local/share/mplayer/font/font.desc loaded successfully! (206 chars)
Using Unoptimized OnScreenDisplay
Using usleep() timing
Terminal type `unknown' is not defined.
get_path('input.conf') -> '/var/root/.mplayer/input.conf'
Can't open input config file /var/root/.mplayer/input.conf: No such file or directory
Can't open input config file /usr/local/etc/mplayer/input.conf: No such file or directory
Falling back on default (hardcoded) input config'
Playing file.mov.
[file] File size is 1467410132 bytes
STREAM: [file] file.mov
Checking for YUV4MPEG2
DEMUXER: freeing demuxer at 0x1829c00
ASF_check: not ASF guid!
Checking for Nullsoft Streaming Video
Checking for NuppelVideo
Checking for REAL
Checking for SMJPEG
DEMUXER: freeing demuxer at 0x181d600
Searching demuxer type for filename file.mov ext: .mov
Trying demuxer 7 based on filename extension
Checking for MOV
MOV: Movie header found!
MOV: 'WIDE' chunk found!
MOV: Movie DATA found!
QuickTime/MOV file format detected.
MOV: Movie header (100 bytes): tscale=600 dur=4140833
MOV: Track #0:
MOV: Track header!
tkhd len=84 ver=0 flags=0x0 id=1 dur=4140833 lay=0 vol=256
MOV: Edit atom!
MOV: Edit list table (1 entries) (ver:0,flags:0)
MOV: entry#0: duration: 4140833 start time: 0 speed: 1.0x
MOV: Media stream!
MOV: Media header!
MOV: Handler header: rlhm/nuos (lppa) Apple Sound Media Handler
MOV: Media info!
MOV: Sound header!
MOV: Handler header: rlhd/sila (lppa) Apple Alias Data Handler
MOV: unknown chunk: dinf 28
MOV: Sample info!
MOV: Description list! (cnt:1)
MOV: desc #0: a4pm (0 bytes)
MOV: Sample duration table! (1 blocks)
MOV: Sample->Chunk mapping table! (33282 blocks) (ver:0,flags:0)
MOV: Sample size table! (entries=297218 ss=0) (ver:0,flags:0)
MOV: Chunk offset table! (33282 chunks)
MOV track #0: 33282 chunks, 297218 samples
pts=304351232 scale=44100 time=6901.389
EL#0: pts=0 1st_sample=0 frames=297218 (6901.388s) pts_offs=0
==> Found audio stream: 0
Audio bits: 16 chans: 2 rate: 44100
Audio header: samp/pack=1024 bytes/pack=1536 bytes/frame=3072 bytes/samp=2
Audio extra header: len=103 fcc=0x77617665
MOV: Found MPEG4 audio Elementary Stream Descriptor atom (51)!
ESDS MPEG4 version: 0 flags: 0x000000
ESDS MPEG4 ES Descriptor (34Bytes):
-> ESId: 0
-> streamPriority: 0
ESDS MPEG4 Decoder Config Descriptor (20Bytes):
-> objectTypeId: 64
-> streamType: 0x15
-> bufferSizeDB: 0x001800
-> maxBitrate: 128.000kbit/s
-> avgBitrate: 128.000kbit/s
ESDS MPEG4 Decoder Specific Descriptor (2Bytes)
ESDS MPEG4 Sync Layer Config Descriptor (1Bytes)
-> predefined: 2
Fourcc: a4pm
MOV: Track #1:
MOV: Track header!
tkhd len=84 ver=0 flags=0x0 id=2 dur=4140833 lay=65535 vol=0
MOV: Edit atom!
MOV: unknown chunk: tref 12
MOV: Media stream!
MOV: Media header!
MOV: Handler header: rlhm/ediv (lppa) Apple Video Media Handler
MOV: Media info!
MOV: Video header!
MOV: Sample info!
MOV: desc #0: v4pm (0 bytes)
MOV: Sample duration table! (3 blocks)
MOV: Syncing samples (keyframes) table! (1854 entries) (ver:0,flags:0)
MOV: Sample->Chunk mapping table! (27601 blocks) (ver:0,flags:0)
MOV: Sample size table! (entries=165466 ss=0) (ver:0,flags:0)
MOV: Chunk offset table! (27608 chunks)
MOV track #1: 27608 chunks, 165466 samples
pts=828156329 scale=120000 time=6901.303
EL#0: pts=0 1st_sample=0 frames=165466 (6901.388s) pts_offs=0
FAAD: Failed to initialize the decoder!
ADecoder init failed
Cannot find codec for audio format 0x6134706D.
==> Found video stream: 1
MOV: Found MPEG4 movie Elementary Stream Descriptor atom (86)!
ESDS MPEG4 ES Descriptor (69Bytes):
-> ESId: 0
-> streamPriority: 16
ESDS MPEG4 Decoder Config Descriptor (58Bytes):
-> objectTypeId: 32
-> streamType: 0x11
-> bufferSizeDB: 0x001000
-> maxBitrate: 4.096kbit/s
-> avgBitrate: 4.096kbit/s
ESDS MPEG4 Decoder Specific Descriptor (40Bytes)
-> predefined: 2
Image size: 704 x 352 (32 bpp)
Display size: 855 x 352
Fourcc: v4pm Codec: '3ivx D4 4.1'
MOV: Track #2:
MOV: Track header!
tkhd len=84 ver=0 flags=0x0 id=37 dur=4140833 lay=0 vol=0
MOV: Edit atom!
MOV: Media stream!
MOV: Media header!
MOV: Handler header: rlhm/txet (lppa) Apple Text Media Handler
MOV: Media info!
MOV: Generic header!
INFO: [yuvscaler] SVCD output format requested in NTSC norm
Data Handler
MOV: Sample info!
MOV: desc #0: txet (0 bytes)
MOV: Sample duration table! (31 blocks)
MOV: Sample->Chunk mapping table! (1 blocks) (ver:0,flags:0)
MOV: Sample size table! (entries=31 ss=0) (ver:0,flags:0)
MOV: Chunk offset table! (31 chunks)
MOV track #2: 31 chunks, 31 samples
pts=829991600 scale=120000 time=6916.597
EL#0: pts=0 1st_sample=0 frames=31 (6901.388s) pts_offs=0
INFO: [yuvscaler] input: frame size: 704x352 pixels (371712 bytes)
INFO: [yuvscaler] input: frame rate: 2997003/125000 fps (~23.976024)
INFO: [yuvscaler] input: interlace: none/progressive
INFO: [yuvscaler] input: sample aspect ratio: ?
INFO: [yuvscaler] from 704x352, take 704x352+0+0, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] scale to 720x360, 720x480 being displayed, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] Scaling uses the BICUBIC algorithm,
etly understood! (id: 2)
MOV: longest streams: A: #0 (297218 samples) V: #1 (165466 samples)
[V] filefmt:7 fourcc:0x7634706D size:704x352 fps:23.98 ftime:=0.0417
] without line switching
INFO: [yuvscaler] without time forwarding
INFO: [yuvscaler] Without luminance correction
INFO: [yuvscaler] Without chrominance correction
INFO: [yuvscaler] black lines: 60 above and 60 under
INFO: [yuvscaler] black columns: 0 left and 0 right
INFO: [yuvscaler] frame rate: 23.976 fps
INFO: [yuvscaler] Scaling ratio for width is 44 to 45
INFO: [yuvscaler] and is 44 to 45 for height
INFO: [yuvscaler] output: frame size: 720x480 pixels (518400 bytes)
viewer
SUB: Read 561 subtitles.
SUB: Adjusted 1 subtitle(s).
SUB: added subtitle file (1):file.srt
get_path('sub/') -> '/var/root/.mplayer/sub/'
Opening audio decoder: [faad] AAC (MPEG2/4 Advanced Audio Coding)
dec_audio: Allocating 4608 bytes for input buffer.
dec_audio: Allocating 49152 + 65536 = 114688 bytes for output buffer.
NFO: [yuvscaler] output: frame rate: 2997003/125000 fps (~23.976024)
INFO: [yuvscaler] output: interlace: none/progressive
INFO: [yuvscaler] output: sample aspect ratio: ?
INFO: [mpeg2enc] Selecting SVCD output profile
++ WARN: [mpeg2enc] Generating dummy SVCD scan-data offsets to be filled in by "vcdimager"
/en/codecs.html!
vo_yuv4mpeg: Using (default) progressive frame mode
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
INFO: libavcodec init OK!
Selected video codec: [ffodivx] vfm:ffmpeg (FFmpeg MPEG-4)
Audio: no sound
Freeing 0 unused audio chunks
na1.mpv
INFO: [mpeg2enc] Horizontal size: 720 pel
INFO: [mpeg2enc] Vertical size: 480 pel
INFO: [mpeg2enc] Aspect ratio code: 2 = 4:3 display
INFO: [mpeg2enc] Frame rate code: 1 = 24000.0/1001.0 (NTSC 3:2 pulldown converted FILM)
INFO: [mpeg2enc] Bitrate: 4000 KBit/s
INFO: [mpeg2enc] Quality factor: 3 (Quantisation = 3) (1=best, 31=worst)
INFO: [mpeg2enc] Field order for input: none/progressive
INFO: [mpeg2enc] New Sequence every 9999 Mbytes
[ffmpeg] aspect_ratio: 2.424242
VDec: vo config request - 704 x 352 (preferred csp: Planar YV12)
Trying filter chain: vo
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 2.43:1 - prescaling to correct movie aspect.
VO Config (704x352->856x352,flags=0,'MPlayer',0x32315659)
VO: [yuv4mpeg] 704x352 => 856x352 Planar YV12
VO: Description: yuv4mpeg output for mjpegtools (to "stream.yuv")
VO: Author: Robert Kesterson <robertk@robertk.com>
stream of 260 Kbps
INFO: [mpeg2enc] Search radius: 16
INFO: [mpeg2enc] GOP SIZE RANGE 9 TO 15
INFO: [mpeg2enc] Setting colour/gamma parameters to "unspecified"
INFO: [mpeg2enc] Progressive format frames = 0
INFO: [mpeg2enc] Using default unmodified quantization matrices
INFO: [mpeg2enc] Buffering 39 frames
lanar, 371712 bytes
*** [vo] Allocating (slices) mp_image_t, 704x352x12bpp YUV planar, 371712 bytes
INFO: [mpeg2enc] SETTING AltiVec for QUANTIZER!
INFO: [mpeg2enc] SETTING AltiVec for MOTION!
INFO: [mpeg2enc] SETTING AltiVec for TRANSFORM!
INFO: [mpeg2enc] SETTING AltiVec for PREDICTION!
nd 42 P quant=3.00 total act= 15155.1
0 0 0%
ds_fill_buffer: EOF reached (stream: video)
EOF code: 1
uninit video: ffmpeg
DEMUXER: freeing sh_audio at 0x133e340
DEMUXER: freeing sh_video at 0x133e5f0
INFO: [yuvscaler] End of stream!
INFO: [yuvscaler] Normal exit: end of stream with frame number 165467!
Exiting... (End of file)
INFO: [mpeg2enc] Guesstimated final muxed size = 3447895490
wait, encoding to mp2 audio with mp2enc...
/Applications/ffmpegX.app//Contents/Resources/mencvcdX: line 208: audiodump.wav: No such file or directory
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [mplex] File file.mpv looks like an MPEG Video stream.
**ERROR: [mplex] Unable to open file file.mpa for reading.
I though It was a conflict between 3ivx and Divx and I removed the Divx component from the Quicktime folder.
Thanks to help
Nobody answer.
It seems I'm not the only who has problems to encoding sound from MPEG-4.
Is there a bug in latest Ffmpegx ?
It seems that the audio codec is not recognized by mplayer. Encode again with the option "Decode with Quicktime" instead of "Decode with mplayer".
I want to burn subtitles with it.
I already encode this file to MPEG-2 and had no problem.
Think it was FfmpegX 0.0.9K
With the M version. I have this problem.
I will retry with a old version of FfmpegX.
Anyway I just registered FfmpegX.
It is really a good application. I often use it.
Thx
Having Strange Problem with after encode!
By Jimbo1 in forum Video ConversionReplies: 1Last Post: 20th Mar 2011, 04:36 -
3ivx question
By Gary Esposito in forum Newbie / General discussionsReplies: 6Last Post: 17th Jul 2009, 17:04 -
3ivx Batch Conversion Available? Possible Script?
By fitch.j in forum Newbie / General discussionsReplies: 2Last Post: 12th Jun 2009, 05:24 -
NEW PROBLEM: Will Not Encode
By totalnewbiedumbass in forum ffmpegX general discussionReplies: 4Last Post: 14th Dec 2007, 10:25 -
3ivX to XviD problems...
By GangstaRap in forum Video ConversionReplies: 8Last Post: 6th May 2007, 11:25
