Hi all,
I was wondering if someone had ever experienced my same problem.
Got some divx material, tried to convert it to a DVD using either the fast DVD preset or the DVD (hi or low bitrate), and ffmpegx 0.0.9m produces a perfect mpg (so the multiplex worked fine, my assumption), and an .img with the DVD.
Mounting the image and playing it through DVD Player (10.3.4 OS X, Dual 800MHz G4, 1GB RAM) the only result is the sound flowing with a still image. If I try to fast forward I see the movie goin on, but when I stop I get once again a still image and the normal movie soundtrack.
The same happens writing it to a DVD-RW.
I tried to flatten the DIVX (the codec I see is 3ivx 4.5.1 for most of them) using DIVX Doctor, but the result is the same.
Any suggestion? Thanks in advance
TMPGEnc Authoring Works 5 Problem
By KTH in forum Authoring (Blu-ray)Replies: 8Last Post: 11th Aug 2012, 05:01 -
ever had this menu authoring problem before?
By uglijimus in forum Authoring (DVD)Replies: 5Last Post: 22nd Oct 2009, 14:06 -
Problem: authoring w/subs
By maumastoks in forum Authoring (DVD)Replies: 3Last Post: 19th Jan 2009, 10:02 -
Problem with DVD Authoring
By Astrogirl in forum Authoring (DVD)Replies: 1Last Post: 5th May 2008, 18:02 -
Problem with authoring NTSC DVD
By JPS in forum Authoring (DVD)Replies: 6Last Post: 17th May 2007, 13:33
