can someone please tell why i can play a certain copy of a movie example troy on my sons philips 710 using princo and ridisk, and when i copy another movie example cold mountain on the same disks it won't work only certain movies work
tia
gibby
Don't play copies. Play original instead to get rid of any problems.
// Znooky -
If all settings are the same and your using the same hardware to copy my guess would be the media. If you can try burning at a slower speed or maybe different media.
Or maybe becasue you're trying to burn Troy, which is still in theatres, and is therefore warez.
try making sure that the final size of the DVD is at least 4GB or more. My Philips 711 will NOT play DVD less than 4GB...just says "no disc". Look in the "DVD Players" list over there on the left, and read some of the issues that people have with your particular model.
mastersmurfiejust a thought
mastersmurfie
Rip subtitles - won´t work.....help
By manutd in forum SubtitleReplies: 2Last Post: 9th Nov 2008, 17:24 -
conversion programs just won't work!
By Sean O'Scare in forum Video ConversionReplies: 19Last Post: 17th Feb 2008, 02:58 -
cd drive rw won't work
By sue1951 in forum ComputerReplies: 6Last Post: 27th Aug 2007, 14:39 -
ffmpegX 0.0.9x r2 just won't work under X.3.9 ?
By Jose Hidalgo in forum ffmpegX general discussionReplies: 1Last Post: 16th Jul 2007, 09:37 -
Autoplay on PC won't work now
By gwoiler in forum Software PlayingReplies: 3Last Post: 31st May 2007, 16:36
