I am having this strange problem, this happened after I updated the firmware on my sony DRU500A to 2.1. I also changed the cables so I could burn at X4. Now it only reads the DVD -R but not the original discs. That is right it can not read the original discs only copied discs and it read at X4 not X2 (As I thought it was locked at X2).
Does anybody know what is going on here? It is giving me a headache.
Thanks.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
I figure it out that it is something to do with the region setting. It does not play DVDs with region settings. I tried playing original dvds with no region setting, it played fine.
I looked under the dive's properties it is showing region 4 which is correct for Australia. Why it would not play region 4 discs then?
I don't want to change the settings from region 4 to region 4.
Can anyone help?
Thanks. -
I am wondering if there is some sort of virus, which changed my region coding. Because I tried region 2 disc, it played fine. But I can not play region 4 discs. Seems like 4 changes are already done by the virus or something else. I have never changed settings. Nobody else touches my computer.
Other possibility is that I did a lot of firmware updates starting from 1.0e to 2.1a. Maybe that altered the region setting?
DVDInfo and windows show 4 changes to go. I did reformat my computer trying to rectify the problem.
Any comments will be welcomed.
Thanks. -
Try switching to a different region (like Region 1), reboot, and switch back to Region 4 using the Windows utility. See what happens. If it continues to fail, get a dedicated DVDROM drive. Fast Lite-Ons go for less than $30 shipped in the US now... shouldn't be more than $60AUS locally I would bet.
Best of Luck,
-Evan-
Same copied Blu Ray only reads sometimes in player, all the time with PS3.
By sevensees in forum Blu-ray RippingReplies: 8Last Post: 5th Mar 2012, 10:57 -
What the hell is Warner doing to their Archive DVDRs?
By Sephiroth666 in forum DVD RippingReplies: 33Last Post: 3rd Mar 2011, 14:31 -
200 Philips DVDrs -/+ $25 Frys
By DJboutit in forum Newbie / General discussionsReplies: 7Last Post: 4th Sep 2010, 11:37 -
Can Sony PS3 system play copied DVD movie?
By coody in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Jan 2009, 00:33 -
Filling DVDRs To Capacity?
By foxbox in forum Video ConversionReplies: 1Last Post: 25th Sep 2007, 10:26
