I have a p4 running windows xp, I have a TDK 24/10/40 cd/rw, Hpdvd100j running on the ide bus. I have a pioneer scsi dvd player on scsi bus.
Now the problem; all the drives work and have the drivers installed HOWEVER, I can not get most software to recognize the drives for writing. For example Video Pack refuses to see anything but a virtual cd. Wont see the dvd rw at all. Ulead movie factory wont see it either and same as nero 5.5.5.4, however MyDvd sees it and writes to it fine. Windows xp explorer sees it and recognizes it when i insert a blank dvd.
I would assume others out there have a HP dvd/rw and have used nero or video pack, could you post reply to let me know if there is something specail i must do?
Thank you,
FnG
Results 1 to 1 of 1
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
