I've downloaded VirtualDub and am having some trouble. I've already captured a avi2 via Scenalyzer using my Canopus ADVC-100. When trying to open this avi file in VirtualDub I get the following error.
Also when I open VirtualDub, the GUI is blank, except for the top tool bar and bottom tool bar. I’m not sure if this is normal.Couldn't locate decompressor for format 'dvsd' (unknown)
VirtualDub requires a video for windows (VFW) compatible codec to decompress video. DirectShow codecs, such as those used by Windows Media Player, are not suitable.
I've never used this program before; a little help would be greatly appreciated.
Results 1 to 10 of 10
Geronimo
Install a DV codec. Panasonic and Canopus make one. Check the Tools section at left. And no, there is nothing wrong with your Vdub. That's how it opens.
Hello. -
Thanks Tommyknocker.
Works with Panasonic Codec, does not work with Canopus Codec. Are all filters recommended?Geronimo -
I don't understand exactly what you mean. If you mean to use all your filters available for each project, then the answer is no. Use the ones suitable for each project. If you want recommendations for all the filters, I can't answer that, since I haven't used all of them myself.
Hello. -
Virtualdub is a great program. You can find some guides to the left.<<<
Filters, there are a lot. I commonly use the HSV and brightness/contrast for color control. You might look at this site for other filters:http://neuron2.net/ . There are others if you do a Google search for 'Virtualdub filters' and maybe some advice on what to use.
Be advised that any filter will slow down Virtualdub. If you have noisy VHS tapes, it may take +several hours to clean them up and a lot of HD space. -
Sorry, my mistake. At first look, I didn't see any filters; I thought I had to download them all. I've found what I'm looking for and working on the AVI file now. I needed the "Null Transform" filter. Looks like I'll see the finished project in about 3 hours or so.I don't understand exactly what you mean.
Thanks for your help.
@ redwudz,
Thanks; those are the filters I was referring to. I've downloaded some but haven't loaded them yet. I need to finish this first AVI, and then I'll play around,
Thanks for responding.
ReddGeronimo -
Well this was interesting; VirtualDub did error itself out due to insufficient disk space. My original capture is 25 gigs; the VirtualDub correction used 87 gigs and didn't finish the job. This program uses an incredible amount of disk space.
I wonder If I can capture the tape again via VirtualDub and use the Null filter and produce a smaller file?
[EDIT] Apparently not. It can't see my Capturing Device
bummer.
Geronimo -
Redd : What did you use for compression? The default compression setting will give you a RGB very large file.
You can set it to DV if you have the codec installed or, my preference if you are going for DVD format encoding, frameserve to TMPGEnc or other encoders. That way you don't need to generate an in-between file that you don't need and will take up HD space.
For frameserving, check the VD guides,https://www.videohelp.com/forum/userguides/87270.php
EDIT: No, Virtualdub will not 'capture' DV.
And how is the audio done? The guide says it has to be done separately. Does this create any OOS, and is this done still using either VirtualDub or TMPGenc?
Obviously I’ve not done this process before.
ThanksGeronimo
Using VirtualDub 1.10
By eteaneck in forum Newbie / General discussionsReplies: 3Last Post: 8th Mar 2011, 16:50 -
Why is Virtualdub doing this?
By skybooks in forum Video ConversionReplies: 4Last Post: 29th Jan 2011, 22:11 -
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 14:26 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 18:08 -
Help with VIRTUALDUB Please !!!!
By spliffy in forum RestorationReplies: 10Last Post: 30th Jun 2007, 09:28
