When I use any Recorder softwares to record the sounds in a video, the output sounds come out HORRIBLE!! The INPUT is very OK, but the OUTPUT sounds so bad!!
How to repair or change sound card ??
I would first get the latest drivers for the card and try them out.
Repairing is not really an option. If it is a bad card, they are resonably cheap to replace, depending on the quality you want and how much you want to spend.
If you are asking about changing a card, you just remove the old one and plug the new one in. If it is on the motherboard, you can still add a PCI card and disable the onboard audio. -
No sense i trying to repair. New Sound cards start at about $10. Turn the power off, then just remove the old card from the slot (if onboard disable in the BIOS), put the new one in an empty slot, boot the system and load the drivers for the new card.
Just take off the left side panel from the case,locate an empty pci slot,plug in and use one screw to fasten or pay technician,.
Sloooooooooooooow down.
Is the sound output Ok with other sound sources?? (CD music, MP3)
How do you know the input is OK?? Are you deriving this from the source?The INPUT is very OK, but the OUTPUT sounds so bad!!
Check line in/mic line levels - adjust for 80% try again.
Check connection between source and computer.
You need to claify your statement.
What video ? Method?......to record the sounds in a video
I agree. Don't buy something new until you know you really need to. That's the #1 newbie mistake.
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 22:03 -
[VHS conversion] Sound Card, Video Card?
By bessiecat in forum Capturing and VCRReplies: 6Last Post: 26th May 2011, 14:02 -
What are the downsides to having both onboard sound and Sound Card enabled?
By c627627 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 15:44 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Question how to change TV card max file limit of 4.1 GB
By jimdagys in forum Capturing and VCRReplies: 2Last Post: 25th Nov 2008, 08:47
