    ontario ,canada
    I tried dvdrb 0.55 and am impressed with the quality.I use vobblanker then dvdrb and finish checking with ifoedit before burning.I'm curious what settings in cce others are using? I have the bias at 25 and the quality precision at 24.I haven't got through a whole movie yet,but what i have checked is excellent.It takes a lot more time than clonedvd,but the computer does most of the work anyway.
    bmiller,ont.canada
  2. Member MysticE's Avatar
    Nov 2003
    Rest assured the default settings are fine and have been carefully chosen to provide the best results on the most DVD's.
    ontario ,canada
    I've read of others changing the settings a bit,and no results posted.I assume the default settings are ok as you suggest,but was just curious.
    bmiller,ont.canada
  4. Member MysticE's Avatar
    Nov 2003
    They are more then 'OK', they've been tweaked a few times since RB's start.
