What software decoder can be used to preview work in progress in both Scenerist and DVD Maestro? Both of these programs seem to want a add in card but perhaps there is another option to use a software decoder.
Maestro -> Cinemaster 2000 DVD player.
I think it's the only DVD player that integrates with Maestro, you can choose to install only the codecs indeed and Maestro will allow preview.
Don't know Scenarist
Zetti -
scenarist 3.x -- it is built in, you select on installation if you are using hardware or software ...
Maestro -> Cinemaster 2000 is the best , but 99 also works fine .. so does the cinemaster that comes on the installation cd ..
latest cinemaster from sonic does not work .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Looks like Cinemaster 2000 is a oldie not available anymore and made for WinNT or Win2000 only. Maybe Im wrong here but I cant find it anywhere.
Originally Posted by Muppet Meat
cinemaster 2000 works perfectly well with XP"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Reccomend a good 5.1 decoder/encoder software
By 1980sumthin in forum AudioReplies: 2Last Post: 25th Jun 2009, 19:47 -
DVD Decoder Choice
By Parc in forum Software PlayingReplies: 8Last Post: 12th Sep 2008, 03:01 -
Combining PowerDVD 7's Audio Decoder and Microsot's MPEG-2 Video Decoder
By Dark Alpha in forum Software PlayingReplies: 4Last Post: 11th Sep 2008, 19:44 -
Problem with DVD Decoder
By alekdaone in forum Software PlayingReplies: 4Last Post: 18th Jun 2008, 15:47 -
what's a DVD decoder?
By johnsees in forum Newbie / General discussionsReplies: 5Last Post: 9th Aug 2007, 18:59
