heres a techincal question, Is it possible to backup a DVD that is 3.56 GB but I want to keep the menu but remove the unviersal and copy right notices, loadup screens can it be done becuase if I just copy there still there if I Re-authour with dvd shrink the menus go away
can I have the best of both worlds, so you put the dvd in and the main menu comes up straight away????
DVD region settings are a joke, I can't believe how stupid people are falling for it
Yes you can, use DVD Decrypter and DVD Shrink in conjunction with TitleSetBlanker.
TitleSetBlanker can be used to remove warning screens, copyright notices on dvds as well as trailers and extras for dual layer dvds. It is also a freeware
Ok shrunk it down with DVD shrink and then used to blank out the start screen, when I imported it all into nero to burn a error message said sometihng about files cupurred and may not play .. then I just let it burn and Im waiting to test it but is that just normal?
DVD region settings are a joke, I can't believe how stupid people are falling for it -
Well, I accomplish this with DVDRemake. I rip my DVD-5 to the HDD using DVDDecrypter or Smart Ripper then I load those files in DVDRemake and edit out all the "Garbage" such as threats, corporate intros, previews, and ect.. then I have DVDRemake copy the files to a new directory and burn that..
It keeps the menu structure intact and lets you really fine tune the disc like you want it and it doesnt re-encode anything.
Also look into getting cloneDVD2 which is an excellent program for keeping menu systems intact but sometimes doesnt let you find and delete all the "Garbage".
I only use DVDShrink to backup DVD-9 discs when all I want to do is backup the main movie itself and not the menus and the other stuff.
When dealing with DVD-5's you can just rip it and then burn it but like you, I dont like all the "Garbage" on the disc.
Just my opinion eh?
I still use DVD shrink for dvds less than 4gb, becuase I sometimes find it does it faster than dvd dycpter
Odd breaks in video/audio authoured with DVD Shrink 3.2 & Imgburn
By bahjan in forum Authoring (DVD)Replies: 1Last Post: 1st Sep 2010, 14:46 -
Hello I'm New & I Have A Question About DVD Shrink 3.2
By taffy1967 in forum Newbie / General discussionsReplies: 3Last Post: 4th May 2010, 05:28 -
Studio 11 & DVD Shrink
By aruba92 in forum Capturing and VCRReplies: 8Last Post: 3rd Jan 2008, 22:10 -
nero 8 & dvd shrink
By jerbevpicasso in forum Newbie / General discussionsReplies: 17Last Post: 24th Oct 2007, 22:36
