  1. I have some vob's that I would like to convert to whatever(mpeg4, avi, mov)Any of those is fine. Please dont reply with "use the search function" because i've spent over an hour looking for help here. All I ask for is to make the movies around 160mb each with audio. I can't seem to get any audio in the finished results.
  2. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    did you try the ffmpegx forum?
    https://www.videohelp.com/forum/index.php?c=6
    otherwise, you should just be able to load up your .vob as the source, chose your codec and begin the process based on your frame rate calculations and audion settings under the audio tab?
    perhaps you need to explore more how the app works.
    http://homepage.mac.com/major4/video.html
    look there first, then click the remaining tabs to get more info on what ffmpegx does
