Im using DVD-lab to create my menu , its good , but if i create a button , for example with red text color , its work good , but in my DVD player, when i push the button, its's color change to purple and look so gay , how can i do to keep my button's color keep original color ?
Actually its more pink in my opinion - Still pretty insipid. Select all buttons in menu - Select show/Hide properties in toolbar above menu -- click on map click small pink box and select another color. recompile project.
In DVD-lab there are 3 colors that you can change for text. One is the normal color, one is the color when selected, and one for when it's activated. These can be changed in the menu directly to the right of the main window view.
This is also the place where you can set link attributes, timeouts, shadowing etc. Use the slider to change each of these colors to whatever you want.
I should also mention that you may need to activate this window by going to "view" and then selecting "menu properties" from the dropdown. -
Thanks, its work now .
And i have one more question , seem to be DVD-lab De-quality my picture , i used a nice picture with hight quality to make background for my Menu, but when compile done , and i play it on DVD player , the movie still keep the same quality , but the menu background picture look so terrible ! How can i improve my picture , or Cannot ?
DVD Lab Pro help! Play animation after pressing button for playing video.
By visualhippocracy in forum Authoring (DVD)Replies: 3Last Post: 26th Mar 2011, 09:21 -
DVD LAB PRO - color map
By blackmiles in forum Authoring (DVD)Replies: 5Last Post: 14th Apr 2010, 03:56 -
DVD-lab PRO v1.6 - "Map" only gives the color black
By Paker in forum Authoring (DVD)Replies: 1Last Post: 3rd Sep 2009, 14:30 -
Freeware that will take a mp4 and do a one button color restoration?
By andersonmilltexas in forum Newbie / General discussionsReplies: 15Last Post: 21st Dec 2007, 22:46 -
multi menus (in DVD LAB PRO 2) with different formats/Button issues
By dblue in forum Newbie / General discussionsReplies: 11Last Post: 18th Oct 2007, 19:10
