Within the last few weeks i have been converting all of my old home videos over to my computer so that i can put them on a DVD. Each file is around 700-800MB and are MPEGs. I thought i would surely be able to get at least 4 or 5 movies onto each dvd, though when i tried (through Roxio 6) i was only able to get 2 of my home movies on.
I personally dont understand why it did this, so i came on here to find out. Also i would like to know of any programs that i can use to make dvds with possibly more movies on each.
Thanks in advance for any advice you may be able to offer.
Adam
I use TMPGEnc DVD Author for this. It also allows you to create menus and chapter points.
If they are too big you can run them through DVD Shrink to get more on one disc. -
At 700MB you should be able to fit 6 of your films per disc. I mean 700MBx6=4200MB which should be fine. Maybe Roxio is re-encoding your sound to PCM? Not sure because I never use Roxio software, but you're right, you should be able to fit far more than 2.
Hello,
If your using Roxio dvd builder it will take more space to make dvds. I'm not sure why but if you choose rough draft mode you'll fit more on it.
My suggestion is to get another program like Ulead DVD Movie Factory or Tmpgenc Dvd Author. Both will leave your movie as is if it's dvd compliant (some do weird things behind the scenes, like Matt_D suggested it might be converting the audio??).
Ulead will work great, and it's pretty fast. TDA is also good. Shop around and see which you like. The value you get these days is excellent as far as the features you get.
are your files dvd-compliant mpeg-2? if they are, you need to try a different authoring software - I use DVD Lab and love it.Originally Posted by Cryose
if they are not, try a different encoder such as TMPGenc for conversion before importing them into your authoring software - a dedicated encoder should be faster than an add-on one in an authoring program.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light"
Weird problem with homemade DVD
By euroboy in forum Authoring (DVD)Replies: 12Last Post: 31st May 2011, 19:49 -
No audio from homemade DVD
By lloydswylie in forum Newbie / General discussionsReplies: 4Last Post: 30th Mar 2010, 15:00 -
Video aspect on homemade DVD
By KayAt in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2007, 16:04 -
Is it possible to overcome read errors in homemade DVD?
By geepondy in forum DVD RippingReplies: 8Last Post: 19th Jun 2007, 23:21 -
Problem Copying Homemade DVD
By Anonymous642 in forum Newbie / General discussionsReplies: 8Last Post: 28th May 2007, 14:04
