Having my first attempt at making my first multi with no success.After loading both sets of bin files in the one vts,how do i seperate one of the sets of bin files to the second vts?I've tried draging them down but they will not move.Hope this makes sense.Thanks in advance for any help.
Double-click the word 'VTS' in the tree view as many times as is needed to create a new VTS then drag/drop each MPG in the correct position.
It's the actual drag/drop that's the problem.I can't get anything to move just a circle with a line across it.
You have to drag the mpeg file and bring it directly ontop of the new vts and it will hightlight then drop it. It will fall in there after a sec or so. If you just drop it beside the vts directory it will not drop there and will return back to the old directory. Make sure to bring your pointer untop the new vts and it hightlights.
Making a multi-track audio CD from a commercial concert DVD ?
By MacPCConsultants in forum AudioReplies: 11Last Post: 2nd Jan 2012, 09:26 -
making teac lcdv2257dvr multi regon
By paul69 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 5th Sep 2010, 04:04 -
FLV - Multi Joiner, Multi Splitter, Multi Advert Removal
By oz_surfer in forum Newbie / General discussionsReplies: 0Last Post: 11th May 2009, 22:16 -
have a problem making multi-episode dvds??
By roboroach in forum SubtitleReplies: 0Last Post: 18th Dec 2008, 16:39 -
Multiple steps to create multi-audio, multi-subtitle DIVX from DVD
By schwarznavy in forum DVD RippingReplies: 8Last Post: 10th Nov 2008, 02:01
