I've got a DVD encoded and I'd like to remove menus completely so all that happens is that I put the DVD in the drive, and it plays the movie. Can anyone suggest a very simple and easy way to do this? Thanks!!!
Results 1 to 13 of 13
Oops, let me clarify a little bit. I've got a proggie that has re-encoded my Divx file to MPEG ready for DVD burning but it's thrown in this little menu with a splash screen. I'd like to simply take out that menu so when I burn it I don't have to hit play, I can simply have it play. Does that make sense? I've got all the VTS_01_0.*** files ready to go, but I'd like to extract the menu out.
Still DVDShrink?
Thx peeps. -
Okay, I've used DVDShring to re-author the files and as we speak I'm burning the DVD, but
.... isn't there any easier way? The VOB file that contains the menu (called VTS_01_0.VOB) is only 56k. So I downloaded the free menuedit version but when I have it simply remove all menuing options all it does is re-create the VTS_01_0.VOB file and it's 0bytes in size. When I burn the DVD and play it the audio begins, but I get no picture (when I fast forward the DVD for half a second the video comes alive... functional, but not practical).
Thx for the help -
I tried this and it seems to work but now I have 99 chapters. Should be 28. Any ideas or settings to change?Originally Posted by jimmalenko
Thanks.Originally Posted by aedipuss
I guess I should explain what I am trying to accomplish. I want to remove or make the menu (created by a stand alone) inaccessible even if someone were to push the menu or title button on a remote control. The movie already plays first.
There must be a simple way. I liked the IfoEdit solution but it creates 99 chapters. trying to find a way that only edits or creates ifo's.
I tried a PgcEdit guide, but it did not work. When I run the disc, I just get black and green screens. -
Well, I guess DVDShrink would probably be the easiest way to get rid of the menu.
Can some one tell me if Shrink in any way re-encodes (changes picture quality) if the original files already fit on a DVD-5? Or if there are any other drawbacks to using shrink just for this.
How to remove the language selection menu from BR Disc
By The-One in forum Authoring (Blu-ray)Replies: 21Last Post: 27th Apr 2014, 17:00 -
Was there ever a case where deinterlacing would simply not work?
By mazinz in forum RestorationReplies: 11Last Post: 25th Jan 2011, 05:53 -
How to remove menu without re-rendering?
By Lippy Lipstick in forum Authoring (DVD)Replies: 5Last Post: 27th Jun 2009, 15:29 -
How to simply turn off MKV subtext
By hanugro in forum EditingReplies: 4Last Post: 18th Nov 2007, 04:49 -
Is This Bad Math or Simply SOME Nerd Calculation?
By moviebuff2 in forum Off topicReplies: 6Last Post: 14th Jul 2007, 09:28
