vobedit is supposely joining,cutting,editing. how the hell do you do the "cutting" part?
i can join the 3 vob files i want w/o a problem, but i need to cut some of the 3 vob file off, and i have no ideia how to do it with vobedit.
if someone knows any other program that joins/cuts/edits and saves it as .vob (so i dont loose like, the audios and subtitles, and most importantely, so i dont loose any quality of the video)
thanks, peace.
VOBEDIT is a demux program
As lordsmurf said, Vobedit is mostly used for demuxing but you can use it for joining and cutting, though it's not as straight forward as a normal editing tool and the smallest unit you can work with is a cell.
Depending on what you want to do, you can split your VOB files by Cell ID or VOB ID. You'll get bunch of smaller VOB files (each will be a Cell or many cells under a same VOB ID, respectively). Then you can rearrange them the way you want by renaming them as VTS_xx_yyy.VOB where xx is the VTS number and yyy starts from 001. Then you can join them. If it goes above 1G, Vobedit will start a new VOB file automatically.
Afterwards you'll need to use MenuEdit or VIDChanger to sort out the Cell and VOB IDs. Doing it manually with Vobedit will take you forever.
Splitting/cutting/joining MP4 accurately...
By The.King in forum EditingReplies: 2Last Post: 2nd Nov 2011, 12:35 -
MOV: Editing: Joining/Cutting/Splitting software
By taboo in forum EditingReplies: 5Last Post: 8th Aug 2011, 18:59 -
need help cutting and joining avi files in virtualdub
By granturissimus in forum EditingReplies: 3Last Post: 31st Jan 2011, 02:53 -
Easiest software for compilation, cutting/joining?
By jiopi in forum EditingReplies: 0Last Post: 14th Oct 2010, 12:31 -
Simple MPEG2 Cutting/Joining Question
By thefiddler in forum EditingReplies: 4Last Post: 21st Dec 2009, 15:39
